#439433 09/17/02 06:50 PM
When I remove the oil filter, the oil splashes all over that end of the engine. No metter how well I wipe it up, I'm prob going to smell hot oil for weeks, while stopped at a light, for instance. Anyone have a good technique for removing that filter? I've tried about 5 ways.
'98 SE V-6 5-spd ASB Silver stock 89K miles in May '05 Like it for Oregon coast canyons!
#439434 09/17/02 07:07 PM
Before you remove the filter, 'spike' a hole in it at its lowest point and let it drain first.....
#439435 09/17/02 07:09 PM
9
For removing the filter? nope, just the best way you have found, is probably as good as it will get. Find yourself some cheap Brake Part Cleaner, and spray the area around the filter AFTER YOU HAVE THE NEW FILTER INSTALLED (Dont want brake cleaner getting into the oil filter hole!) The oil will come right off the motor without even having to touch it with a rag! -Nick
"Moore has also accused the American people of being the stupidest, most naive people on the face of the Earth. And after last weekend, he's got the box office numbers to prove it!"
#439436 09/17/02 07:16 PM
Let the oil drain for 10 min. before doing the filter. Wrap old newpaper around the exhaust manifold and try to keep the filter tipped up as you pull it to minimize spilling on the block/exhuast/hands/eyeballs. Toss out the newspaper and wipe up where you can.
#439437 09/17/02 07:57 PM
Listen to the "Old Man" Terry H. (Nothing derogatory intended Mr. H ).
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#439438 09/17/02 09:35 PM
Thats OK,old can be a good single malt!!!!
#439439 09/17/02 10:59 PM
Tried the spike. Still got a flood when removing the can. Tried holding vertical, ragging, masking and wiping. Want to try the brake cleaner trick, if I don't find anything better. I may also try the spike, then crack the can off just a little, to minimize the flood. Thanks for tips so far. More?
#439440 09/18/02 12:00 AM
E
E
Along with putting a hole in the end of the filter, I use some .015" aluminum flashing cut to roughly 7"X 8" and put it up tight against the block and behind the lip of the oil filter. Bend the flashing slightly to keep the oil running down the center of the flashing into the drain pan as you start to unscrew the filter. This does work but I usually still spill some oil on the exhaust. It eliminates alot of the mess, but I still end up using brake cleaner also. Ed
#439441 09/18/02 04:36 AM
The OF suggested covering the y-pipe in aluminum foil. I do that and finish off spots with brake cleaner.
E0 SVT, lightly modded
#439442 09/18/02 08:30 PM
I very, very slowly "crack" the filter and let it trickle down the outside of the filter till it stops before removing the filter completely. Also, I bring the car to a car wash with an under car wash program. No problems.
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
