Page 2 of 3 1 2 3
#438707 09/17/02 05:06 AM
Webmaster
Webmaster
With a Quaife, it just spoils the fun. I'll be looking into removing the TC module this fall.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
#438708 09/17/02 01:07 PM
TGO Offline
Yes...everythign you need to make it work is there, the switch is for turning it on and off. Daveandrews had a problem where somehow it got turned on while his car was in the shop. On the older cars the PCM controlled it and it worked differently than the "throttle stretcher" in the older cars. It basically cuts spark and timing when it kicks in...not very pretty. The TC is useless..it cuts power to the wheels when slip is detected. Careful driving is far superior. Of course, if you do heartless point a to point b driving...go right ahead, but for someone who likes to get on it every now and then..or someone who regularly autocrosses like dave..it was a MAJOR annoyance. (no switch to turn it off!)
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#438709 09/17/02 01:45 PM
The TC (NON cable Stretcher) doesn't cut spark and fuel till above 53MPH. It applies the brake to the slipping wheel so torque is transmitted to the wheel with more traction. Still, it doesn't always work smoothly. An explaination should be in the Owners Manual (IIRC)
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#438710 09/18/02 07:14 PM
N
N
so simply buying the switch won't give me TC? I had it on my 95 and it worked alright for poor weather. If possible I would like to get it running as long as it is defeatable.
05 Legacy GT Turbo 5speed 99 SVT GRN/TAN (sold) 06 Ford Explorer EBv8
#438711 09/19/02 04:19 AM
I am Canuckian
I am Canuckian
IIRC there was 1 or 2 versions of the system over the years. Personally I love my T/C on the Contour and wish my Mystique had it to. Case in point there was a freezing rain storm last March. I run a pizza store and several of my drivers were having trouble getting around. In one case a street with a considerable incline in ice was required to have a couple of deliveries. My one driver went there and had to park the car @ the bottom of the hill as he couldn't get up it. I took the second order about 10 min later. Got to the bottom of the hill and pushed down on the pedal not letting go till I got to the top of the hill. Yes the T/C system made a hell of alot of noise, but I was litterally up the hill in no time. So to me the system is very functional. As proof that I don't know how to drag I got one of my best times while the T/C was on . Guess I need to work on my launches. Still 16 flat is not to bad with the T/C on.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#438712 09/20/02 10:02 PM
There was the electro mechanical version in Contiques up to 97 and I have heard, early, early generation Cougars. After that, Ford went completely electronic.
#438713 09/20/02 11:55 PM
so all the controls are on SVT's except for the switch which means that it ready to work but it doesn't? right??or does it work??
export the imports
#438714 09/21/02 01:58 AM
My SVT had working TC without the switch. The switch was added later as it was discovered that the harness was there for the switch.
#438715 12/16/03 03:22 AM
So has anyone just installed a switch and activated the TCS? I am also curious if anyone has installed a switch and activated the TCS. My father has an '02 focus and it behaves much differently than my car in wet conditions.
I'd appreciate anyone's input.
Thanks
Tim
Timothy Grimes 98 SVT #2132 82 320i -Now armed with a hairdryer-
#438716 12/16/03 03:53 AM
It's not that simple.
If you have TCS then it is ALWAYS on. The switch is used to turn it off.
To date only that one SVT has been found to have the TCS installed.
Page 2 of 3 1 2 3
