Posts: 1,399 |
OK, this is going to sound like a stupid question, but is the front splash guard (under the front bumper) supposed to be loose or attached?
Cheers, Phil
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 8,445 |
it should be attached on each side to the unner fenders by two screws and to the crossmember by about 7 or 8 screws. the front of it actually sits on top of the lower part of the front bumper..
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 1,228 |
Decontented in later years so probably wasn't absolutely necessary. Usually the rubber "spoiler" or splash shield under the bumber was to icrease air flow through the radiator. It creates a lower pressure zone under the car and allows more air to flow through radiator and out of engine compartment.
Like underhood insulation, it isn't completely necessary.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 9,602 |
Originally posted by Contouraholic: Like underhood insulation, it isn't completely necessary.
I completely disagree. Another thing it does is keep high speed air from entering & pocketing in the engine bay, thus lifting weight off the front end. That would be a very important feature for safeties sake! It also helps decrease drag.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,228 |
Originally posted by DemonSVT: Originally posted by Contouraholic: Like underhood insulation, it isn't completely necessary.
You may be right, but Ford disagrees with you. They decontented it.! Since my SE is limited to 112 MPH, and I don't often have the opportunity to drive that fast, the lift problem doesn't seem to be a problem for me. Since I get 32MPG Highway, drag doesn't seem to affect me either. I know anecdotal evidence doesn't prove anything, but still, I haven't noticed any detriment to not having it.
Posts: 5,854 |
I think it's important to note that the splash guard on the SVT's is different from the ones on a standard contour. So it might not be an issue on 112mph limited contours, bu tthe SVT goes much faster
1999 Silver Frost SVT
#609 of 2760
Posts: 1,399 |
So I should be talking to the dealer about reattaching it after they did the work on my steering rack then?
98 Silver Frost SVT
Posts: 95 |
If they broke the (Torx head))screws (or left them out) that hold it yes complain, else do it yourself. BTW is it a splash guard or an aerodynamic shield device? I would go with splash guard as the major function
Posts: 16 |
I took mine off. I found it is much easier when trying to change the oil. Plus (and it could just be my imagination) I found that I can coast better without it.
Troy
98 E0 Silver Frost SVT
Born 7/15/1997
My B-Day 7/16/1979 Coincidence....Na
SCA CAI
Sho-shop Hi Flow Y-pipe
Custom Cat-back w/ Borla XR1 Mufflers
Sho-shop pulley set with crank damper
Magnecore Competition Wires
MGK Iridium spark plugs
Posts: 263 |
On my 96SE I have the problem when water hits the drive belt, I loose my power steering and alternator for 3-4 seconds. The drive belt slips, I here a squeel and I get my power back.
This only happens at slow speed through large puddles of water. I believe this was fixed on later model contours.
It was scary... one day I was taking a slow turn and lost my power steering and had to arm-strong the steering to miss hitting another car.
1996SE sports package, Duratec MTX No mods yet.
80K Kilometers.
Wife has 1996GL Zetec ATX.
