Posts: 10 |
My water pump went out on my 95 2.5L contour at around 75,000 miles.
1995 V6 ATX LX Contour 1993 V6 Ford Thunderbird Super Coupe : 14.371 @ 95.5mph with lots o' wheel spin!
Posts: 1,040 |
Well further to my May 12 post above re my '97 I now have to report failure of the black plastic OEM wp on my '98 at 62,000 miles on May 31. This time 55% of impeller was still wrapped around shaft although not turning due to crack. Three other pieces totalling 40% retrieved, 5% missing. Cone was again OK, with minor scuff marks. New metal impeller Tredex(GMB) pump now installed.
1998 Mercury Mystique Ls v6 VIN 1MELM66L1WK616503
Posts: 7 |
98 E0 SVT, built 5/97, purchased 12/97, vin on request, write jnathanj@earthlink.net for VIN.
Pump failed 6/2002, 44xxx miles, rapid overheat, but thanks to this group have developed habit of checking temp gauge with every scan of the left sideview mirror, so shut down before I got to the red zone. But, that's relative: the car ran N^ORMAL all its life, which makes the RMAL^| zone that much further away.
Replaced pump with Ford part after service advisor agreed to a them/me 80/20 split for the bill. Out-of-pocket: about $200: $100 for the flatbed towing, $100 for my 20%.
Service advisor showed me the new part, but I couldn't see the impeller, so have no idea what quality is(n't) there.
I know this is an old thread, but a few more bytes won't hurt, right? One more for the archives. I'll log my experience to Blue Oval also.
Posts: 259 |
Adding my name to the list...
Impeller failed at 119000 km. Dealer: "The impeller has disintegrated all over the place..."
Eric B. Ottawa, ON, Canada 98 Mystique V6 5spd. Toreador Red Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit http://photos.yahoo.com/LBuzzer/
Posts: 4 |
I just replaced my waterpump in my 95 SE ATX yesterday(7/10/02)at 79,242 miles. I drive the car long distances at late night early morning hours regularly, but fourtunately I happened to be near home when the temp hit the red! I replaced it with one from Advance Auto which is also plastic. I only found about 1/3 of the original impeller so I guess the rest of it was ground down to a fine dust(I HOPE!). I can't see how any large pieces could have gone into the hoses to cause restriction. In anycase, I changed it in my driveway along with the thermostate in about a half an hour and now the car seems to run just as it did originally. Should I go buy a metal impeller waterpump and replace my new replacement just to be safe??? Al
Posts: 703 |
Arrrg mine just went (I think) ordered a new one anyway.
90k miles 97 lx
Seeya FUseface "Superhero Extrordinaire" "I am Nigh-Invulnerable!" 97 LX Sport
AIM:MiguelAD8
Posts: 11 |
mine went at 50,000 e-mail for info
Posts: 1,041 |
Anthony Mata (Amata@ortc.com) San Jose CA SVT Contour VIN #1FAFP68G9WK215731 Water pump failed about 52K- Replaced at my expense.
Engine just died at 64K- Also to be replaced at my expense.
Please get back to us if you hear any new info.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 78 |
Just lost mine a few weeks ago at 73,220.
Rob, e-mail me for my VIN: ajchyko@catvexpress.net
'98 Contour LX-White 2.5L ATX 73,250 miles KKM Tru-Rev / FMS Wires & Bosch +4s 19mm BAT rear swaybar
Posts: 88 |
Relaced my WP today with a NAPA/GMB. Found the old one to be free of defects- it's going into the spares bin. Easy job- had the new one on in less than an hour, so don't let difficulty stop you. The gasket came off whole- no scraping needed.
'98 SE V-6 5-spd ASB Silver stock 48K miles in May '02 Like it for Oregon coast canyons!
