In reply to:
You're treating the failure strength as linear...fatigue life vs. load for a connecting rod would be a curve.
How do you plan on calculating all of the dynamic loading without some high end software even if you did have the geometry? Also, where can you get material /fatigue specs for a sinter-forged material?
You're correct with your first statement. I used the example to teach the concepts to anyone who will read it....not meant to be a true representation of the strengths/limitations of the rod.
As it was the post was long and wordy.
I am a Materials Science Engineer and much of my focus has been directed to 3 areas: metallurgy, silicon-on-insulator technology with burried oxide layers, and materials characterization with SEM, FESEM,TEM,AUGER, and a few others.
I may be able to get a hold of some software, but that is not really necessary to get an educated 'idea' about the strength of the rods.
My plan is to get the information on the type of material and the manufacturing process that the rods are constructed with, hopefully from someone in the 'know'...in fact I was hoping YOU could help with that, even though you may not get all of the pertinent information a little would be a start. Anyway, I can just do something as simple as start looking for abstracts from metallurgical journals that describe tests on the same type of materials. I also have some reference materials that conver sinter forging a little bit but I will still need to do some reading.
I can probably get cyclic fatigue results on the metal as well most likely from the original journal reports when the process was introduced.
AT the very least, I can research and find UTS, K1C fracture toughness and the variety of materials data that can give some idea on the material's strengths.
As far as sinter forging: Sintering has long been used to get complex shapes for a part from powdered metals while giving very consistent properties to the part throughout its entire cross section. Additionally the sintered material resists creep and distortion (ideal for high temp, high stress environments) because it is formed from uniform grains and grain boundaries which resist the movement of dislocations through the material. This also would have a great resistance to crack propogation as cracks that are less than catastrophic will be blunted by these grain boundaries (less likey to jump from one grain to another). This doesn't mean it is the 'best' material, whatever 'best' actually means. It will be less flexible and prone to catastrophic failure rather than gradual failure. Still, they are very strong...I have nice article here in one of my heat treatment magazine that shows a sinter hardened FL-4605 family of alloys that have UTS ranges from 31KSI to 153KSI with HRC values from 32-92.
I am bombarding you with this information because I assume you are a mechanical engineer of some sort and will likely understand some or all of the concepts. Forgive me if I am wrong in that guess about which engineering background you have, but hopefully you will understand my point that some 'rough maximum value' could be derived from the basic data available, even if we don't know the exact processes involved. I also am hoping to overcome your skepticism and convince you that given enough information I could do what I am claiming.
Tom
warmonger
