Posts: 3,465 |
Originally posted by Kremithefrog: thank you very much....the parts store here keeps them outta reach, so i was unable to cross reference.... are they worth it?
to me I say yes worth ever last penny it cost cause of the nut on the end... Ever had a BI**H of a time getting the filter off I have once and that was the first time I cahnged the oil after buying the car.
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 21,653 |
other than the nut on the end,, is it better? i'm not worried about getting it off.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 974 |
Yup they do have an oil filter for the Zetec....think you are rite...the 2004....cross refs are on back and someone, somewhere has a book in their store that broke it all down.
I use the Castrol Syntec and YES, I did notice a performance gain from it. It was expensive but a good idea.
To remove it, turn the wheel to the left a bit. Then use a band filter removal tool. Just needs a few grunts and then remove it with your hands.
Richard's tips for the day: Take a clean finger and lubricate the rubber ring on the filter with the new oil you are about to put in the car. To avoid damage caused by "dry starts", put a small amount of clean oil into the filter before you reinstall it.
And be careful of 10minute oil change places. They can say one thing and do the other...and have you tried removing a drain plug they put in?? Once had a car that I knew went to a 10 min oil change place, had to use torque wrench, then vice grips to remove a drain plug that those FREAKS had installed with an impact wrench and stripped the threads...don't trust em!
L8R Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you
RB&LB
causing problems in Huntsville
Posts: 21,653 |
i have noticed good things from running mobil 1... i just wanna know if the K&N oil filter is worth it. i didn't have to turn my wheel to get oil filter off. it was just really tight and had to get the metal band filter wrench.
98.5 SVT
Posts: 3,465 |
I was the one who showed that the filter number for the contour is cross referenced on the box and in the K&N filter book. I broke 2 oil filter wrenches before I said f**K it and stuck a flat blade screwdriver into the filter to get the original one off. is it worth it I think so do I see peformance gains NO it's a frickin' oil filter. does my oil stay clean for the most part yes.
aka ZetecRacing
Posts: 682 |
I looked in the K&N oil filter book today and it didn't reference Focus or ZX2 at all... did I just have an old one?
Posts: 50 |
I'm an Amsoil user for life! They have filters as well. Check out their site. http://www.amsoil.comJohn
Posts: 21,653 |
anything called am-soil is scary,,, i'd rather have amgoodoil
98.5 SVT
