Posts: 287 |
Alright, I already told you guys my problem about the wobbling and swaying and i bought some koni's to solve it and it did  but one thing i realized that at higher speeds when i jerk the "ONLY" right the rear end likes to whip out from left-to-right....when i jerk the wheel a little left it does not do this...Can someone help me out a little ??? thanks mancho
04 Blue WRX
-Rota Subzero's 17in gold,Cobb Tunning Stage 2 93 octane, tein springs, 3in -turboback with magnaflow muffler + 1 resonator  2 1/4 up-pipe Former owner of Conniethecontour 99 CSVT...My first love
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Are they adjusted the same? Could one Koni be real stiff and the other loose? Check all you bushing's and make sure they are all in good shape. Otherwise, don't jerk the wheel at that speed. I wouldn't! Are you wanting the rear to come around or not!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 1,451 |
Check the rear trailing arms. I had this same prob. "back end swinging out" and it turned out one of the arms had a bend in it. If that's the problem the part is only 65.00 from ford, if it's only one side, and they charged me 33.00 to put it on.
Vinny 2000 T-RED CSVT
MODS: 18" REV model 2 ST200 struts/Roush springs
CTA intake Pipe/K&N Filter
Dtec Heatshield
Optimized TB
True Duals w/ magnaflow mufflers/resonators
Posts: 2,166 |
I had the same thing happen following a Tow on a flatbed. They hooked my car up by the rear control arms, and bent them badly.
Not a pretty site.
- Zack
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 287 |
Alright....I will have to say that when i was doing my struts.....I did see that one of my (not sure of the name) but where the rear sway bar hooks up too...is kinda of not so stiff....and what is that called?? I am not sure  thanks guys
04 Blue WRX
Posts: 10,015 |
Ask Tim or Dave to look at your rear control arms and see if they are bent. Tim's were from sitting the car on jackstands via the trailing arms. Big NO NO! Luckily I was able to remove them and straighten them for hiim at work.
It does sound like one or both of yours are bent too. Did anyone jack up the rear end from these?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 287 |
I dont think anyone has jacked up the car from there...but im not sure.....but for my first question I found out those are just the endlinks....are they suppose to be stiff because if so I dont think mine are....I have to get rear brakes soon so i was wondering is there new endlinks i could get that are better or could i just get new bushings...?? thanks
04 Blue WRX
Posts: 10,015 |
Those aren't the endl links. End links are attached to the sway bar.
Speculating what your problem is will keep us going around in circles. Just let Dave, Tim or myself look at the car and really see what's wrong with it.
AUSSIE ENDLINKS $70
Posts: 63 |
get the toe set on the rear properly. Then check to make sure the tire pressures are the same.
I would then check your cross weights (do you have any heavy junk (subs, battery etc) in the back?
Posts: 19 |
Had a somewhat similar problem in the rear....it was very jumpy/irratic but also had the famous clunk.(99svt) After many hours and new parts(struts,stabilizer links etc etc)found that is was the tie rod bushing that attaches to the chassis on the left side. Found this during strut replacement....replaced it...clunk is gone and back is very stable over bumps
