Page 5 of 5 1 2 3 4 5
#432487 01/18/03 06:27 PM
Thanks Josch,
I was afraid it would be complicated, and it sounds like it is. The reason I want to turn on the fans is just to keep the engine cool while I am in slow traffic, or stopped. The fan is not turning on until the gauge is at the top of the L. The car does fine when I'm at highway speeds, with the gauge staying at the R-M. I've given up on Ford being able to fix it, and I'm trying to figure something out myself.
#432488 01/19/03 06:02 AM
First thing I'd do, is use an infrared temp gun and watch the ACTUAL temperature that the engine runs at (at the thermostat outlet), at the actual point that the fans kick on, just to VERIFY that they ARE, in fact, coming on too late. You may have a faulty reading temp gauge. Once you verify that the temp is too high (outside specs), when fans kick on, then figure out WHY. Meaning, Is it the ECM, ECT sensor out of range, or some other issue (maybe resistance in a wire or connector)? There IS a logical explaination to your problem, and just because FORD dealer couldn't fix it, doesn't mean it's some big huge unfixable problem. It just means that that technician that was working on your car that day DIDN'T know what he was doing (actually quite common today in our day and age). It IS hard to find good techs these days, but this is why I prefer fixing my own cars, and eventually even became a tech myself, because I can take the time to study up and figure out what the real problem is, and now have figured out how to make a living doing so. I think you could figure out how to fix this problem on your own car, because anything else you do to it, will just be a bandaid. Better to fix it right. So go find an infrared temp gun, or pay a shop like 20 bucks or something, to give you an actual temp reading at the thermostat outlet housing when the fans turn on, and then go from there. That's what I'd do.
'95 CONTOUR SE -Enkei 16s -SVT wannabe -Dual escapes w/ 2 1/2" stainless tips -True LED taillight conversion -Audi Xenon Projector Retrofit -Mp3 deck, dual 10s
#432489 01/19/03 02:05 PM
Good point. Actually, I have an infrared gun where I work. I'm just getting frustrated with the whole ordeal. I've started trying to work my way through the service manual, and figure out where the problem is. I don't think it is the temperature gauge. I'm suspecting the temp sensor, the ac shutoff switch, the wiring, or the ecu.
Thanks for the help.
