Posts: 118 |
i saw that someone posted awhile back about the focus short throw shifter working on a contour..just wondering if anyone has tried it on their tour?if so how easy is it to install?and how well does it work? there are several on ebay now for about $70,made by obx..anyone have any info on these?
98 silver frost svt no cats/magnaflows kkm true-rev white hvac ford blue calipers more to come!!
Posts: 3,419 |
The 98+ Contour MTX uses the same shifter as the Focus. So, any shifter for a Focus should fit a 98+ CDW27 (including Cougar).
Posts: 12 |
I have one on my car, but you should save the $70 and just cut about 2 inches off the stock one. That is the only difference I could see.
Ground Control Coilovers Koni Adjustable struts Sub-frame connectors Slotted rotors Carbon Fibre pads Stainless Steel Braided line KKM Intake Pro-Flow Mass-air Meter 22mm rear sway bar Polyurethane motor mount inserts
Posts: 460 |
The B+M Short Throw has a solid aluminum pivot point. The stock shifter does not. The short throw has a much more solid feel. *Do Not* cut the stock shifter! The throw angle is different on the B+M and it makes your throw shorter. If you cut the stock shifter you will increase your throw distance, and in effect lengthen your shift time. It will be a shorter shifter but not a short throw shifter. (function vs. fashion)
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
Posts: 3,237 |
Originally posted by Po-Jay: If you cut the stock shifter you will increase your throw distance, and in effect lengthen your shift time. It will be a shorter shifter but not a short throw shifter. (function vs. fashion) Eh Jason, were you on drugs this weekend? Explain this one to me? I cut mine down 2" and I can definitely tell you the throw is shorter. And I am $140 richer too!
Posts: 1,428 |
Posts: 620 |
Originally posted by Po-Jay: *Do Not* cut the stock shifter! The throw angle is different on the B+M and it makes your throw shorter. If you cut the stock shifter you will increase your throw distance, and in effect lengthen your shift time. It will be a shorter shifter but not a short throw shifter. (function vs. fashion) I see you have not yet discovered the secret of GEOMETRY..
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
Posts: 460 |
Originally posted by Stazi the Aussie:
Eh Jason, were you on drugs this weekend? Explain this one to me? I cut mine down 2" and I can definitely tell you the throw is shorter. And I am $140 richer too![/QUOTE] Okay, I may have been on some substances this weekend, but let me give a more intelligent explaination of what I meant. (It was a long weekend) Okay, I retract the longer statement and replace it with Uncomfortable and Awkward. The stock shifter has a different pivot point angle (that I am positive of)... The B+M is set up to be a more comfortable as well as shortend throw. Even if I am on crack, I think that you could see that the solid construction and aluminum pivot point are a worth while improvement. It is disgusting that Ford attempted to build a "Sports Sedan" worthy of an entry level Bimmer, yet left the sloppiest shifter and linkage that they could produce, in place. Cut down or not, it is still a crappy set up... IMHO. Oh, and thanks for calling me out Stazi! Now everyone is aware of my habits.  (How the hell are you, BTW?)
Po-Jay
Posts: 3,237 |
Jason - I am pretty bloody good, lately despite some SERIOUS shiz going down in my life. I am overdosing on a 6ft blonde that rocks every part of my world, and I am loving it!
Oh and the SVT has never looked or driven better, and it can only get better ~ turbo/quaife/flywheel etc!
I know that the B&M feels nice, but I think it beacause it has a heavier shaft, thus making the shift effort easier - that's what it seems like to me, and I drove a B&M eqipped Tour last night, so it is fresh in my mind. I am going to experiment with adding weights to the highest point possible on my cut down shifter to see if it helps.
Posts: 460 |
Originally posted by Stazi the Aussie: Jason - I am pretty bloody good, lately despite some SERIOUS shiz going down in my life. I am overdosing on a 6ft blonde that rocks every part of my world, and I am loving it!.... What is this??? Stazi is becoming a "kept-man"??? Say it isn't so! lol. Good Luck!
Po-Jay
