Originally posted by Bill 97SE:
If the light has gone off is there still a concern or should I just forget it?
It depends! (Don't you just love definitive answers
If it was something simple, like your gas cap was loose, then it isn't something that you need to worry about.
But it probably means that something is starting to go bad. If you go to Autozone, you can get the code pulled for free. This will put your mind at ease.
If it is something that is starting to go bad, you can make a decision about fixing it now (so that it doesn't affect other things), or leave it until it really needs to be replaced.
