#431182 09/07/02 04:35 AM
I know the using the O/D accounts for better gas mileage, but what about power? I've got a 98 2.5 dura w the button on the atx shifter...do you use it or not?
98 SE sport 2.5 dura atx-silver painted silver dash and red under the hood mesh grill, knauberized, aftermarket fogs, cone filter, alpine head unit 50x4
#431183 09/07/02 06:48 AM
On the highway, yes. The engine revs lower. In town, you can use it or not. I rarely use the button. Leaving O/D on works just fine for me. You wont accelerate any faster with it on or off.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#431184 09/08/02 05:44 AM
thanks, i was just wonderin
#431185 09/08/02 05:26 PM
N
N
ive read some where if u have it off it changes the tranny's shift points better for acceleration in some cases. if this is tru i dunno. but it does make a difference i turn it off to have the car down shift faster on the highway.
but say i want to accelerate quicky i just pop it in first then 2nd at about 5500 rpm. let off the gas a little bit when shifting and then punch it. and the car flies forward. and eventually shift into D. third gear. and to go in forth i just press the od button.
ive noticed a difference when shifting from 2nd to D. if od is on the car ties to go into 4th. and then it floowed by a thud. which isnt good. so best leave to od off when doing that.
Experience is the worst teacher; it gives the test before presenting the lesson. Why do you need the cats when u have dogs 04 WRX - TOTALED 3-5-05 Previoius Owned: 96 Contour LX with svt kit
#431186 09/08/02 05:53 PM
thats interesting, all that shiftin around hasn't caused any tranny probs? if not - then cool, but if so....
#431187 09/08/02 06:38 PM
N
N
y would it cause problems, its just like having the car shift by it self im just controling it. just have to be careful of the thud that happens when od is on. and shifting from 2nd to D.
#431188 09/09/02 02:01 AM
that makes sense, thanks
#431189 09/09/02 02:57 AM
N
N
here is something i would love to have but its just 2 dame expensive
http://www.levelten.com/store/ford/items/electronics/ford_shiftronic.htm
#431190 09/09/02 05:54 AM
Driving around with the OD OFF will cause the transmission to heat up quicker and possibly overheat at higher speeds.
Our ATX is made to work with a locking Torque Converter.
Keeping the Torque Converter Clutch disabled, will cause additional friction within the Torque Converter,
that the transmission isn't desgined to work with.
This will cause added heat, and as it is, our ATXs aren't designed to remove that heat effectively.
For short periods, it is okay, but not for lengthy drives.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#431191 09/09/02 08:21 PM
W
W
If you wanted that much control over your gears, why didnt you get a 5 Speed. All that playing around with an ATX isnt good.
