Posts: 3,636 |
Banner stolen from focaljet  So, with the upcoming turbo, not to mention removing/moving weight in my car is a nice/STS legal mod that can improve handling. So the dyna batt came up as an option, and of course I went looking on line. I've stopped here. http://www.stealth316.com/2-dynabatt.htm I think the "dyna batt" (Now in quotes) is a great idea for battery relocation. However, I suspect I'll be getting the Hawker Genesis G16EP or Odyssey PC 680 Why because that appears to be what a dyna batt really is. It appears the performance data as well as the dimensions are identical. So what do they look like? Yet they cost about half as much.  Any comments from the peanut gallery?
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Administrator
Administrator
Posts: 5,037 |
HAHA!!! Wow!! DynaBatt unmasked! I wish I had that info when I dropped $60 on a new battery last year. Good find Tony!
Looks like you can get a %10 discount when 5 are purchased.
Posts: 1,225 |
Gotta love the internet!!!
Great find Tony, made my decision a little easier re: battery!!!
Ryan
Latest Mod: Mirko Splitter
Posts: 5,296 |
They have the same cold cranking amp rating as the factory unit right? Looks like something I should get while doing the 3L, especially after seeing how small it is compared against normal car battery!
Posts: 3,636 |
Originally posted by 1st 3L 95SE Wannabe: They have the same cold cranking amp rating as the factory unit right? Looks like something I should get while doing the 3L, especially after seeing how small it is compared against normal car battery! Not even close to the factory CCA, if you read the link, these are not recommended for cars used in cold climates. So only use this if your car is a toy, or if you wanna switch in a regular battery during the winter time. There are larger dry cell batteries that have a CCA that "approaches" but probably doesn't meet the stock battery's CCA rating. HTH, TB
Administrator
Administrator
Posts: 5,037 |
But, if you live in Texas, you can use it year round? :p
Posts: 422 |
5 stars for you! Excellent find!
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 816 |
So are you putting it in the trunk? How much is a relocation kit if so? If not, how will you hold it in the stock location?
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 316 |
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 1,559 |
Personally, I think if a relocation to the trunk is in order. I'd put one or two full size batteries back there and improve the weight distribution of the car instead of making it lighter.
