Page 2 of 2 1 2
#43067 07/10/02 03:35 AM
Is that screen really necessary?
2000 SVT-Black-
SHO CAI
SHO Front tower brace
super white lights
yellow fogs
limo tint all around
#43068 07/10/02 03:48 AM
The screen is part of the SVT airbox (not positive, but don't think it is in the non-SVT setup). The BAT catalogue has the screen's Ford Part Number, so give BIll Jenkins a call or mosey on down to your local Ford dealer (if you dare) and get one if you want. It goes directly prior to the MAF in the airflow (i.e. between your MAF adapter and the MAF, or at the MAF end of the airbox).
This is not stone cold fact, but my understanding of the situation: The screen is to "straighten" the air flow and allow the MAF to make more accurate measurements. Why is it only on the SVT? Because it utilizes a conical filter from the factory (I think).
Can you get by without it? Sure, I haven't really heard of any major problems without it. Would Ford put it in if they felt they could get by without it? Doubtful. Take that for what it's worth.
#43069 07/11/02 04:31 PM
You could go to the hardware store and buy some screen cut out a piece put it over the apadter then filter over it and you have the screen. This is what I did for a little while then I took it out and now I have the orignal screen back in now. I don't think there was a diffrence with or with out it. The reason I put it back in was I was ordering from bat and got there MAF gasket to see if it made a diffrence. Not sure if it made a diffrence since I did a tune up and that is what it really needed. I may take it out again and see what happens just haven't gotten to it.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
#43070 07/11/02 05:17 PM
Old discusssion -
Don't need the screen with the KKM.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
Page 2 of 2 1 2
