#430039 09/06/02 02:17 AM
This is kinda long, but hopefully has all the info needed to assess the problem.
I have a bone stock 95 SE ATX with 80K miles that has an intermittent shifting problem. When driving at any speed, although typically when the tranny is in OD, the tranny starts to slip and the RPM's rise. If I stay on the throttle when it slips the engine seems to hit a rev limiter at about 4K RPMs. Sometimes when I let off all is well for awile, but sometimes it shifts randomly into 2nd or 3rd - these random shifts are sometimes very hard and sometimes not. This may continue for a few seconds or several minutes. The problem then disappears and the tranny works perfectly for more than a week and several hundred miles - or the problem may return in a matter of minutes. This has happened in both wet and dry conditions, after only a few minutes from start-up or 30 minutes or more after start-up.
The first occurrance was about 6 weeks ago, the second about a week ago (and several hundred miles), the third was 1 day later, and now the fourth tonight. The check engine light (or any other warning light) has never come on and the engine is running very smooth and strong. The tranny fluid level is good and the color is a nice pink. The fluid was flushed about 6 months ago by a reputable mechanic using the type of machine that hooks up to the cooler lines and does a complete fluid change using the tranny pump (I watched him do it).
I think the problem is electrical, since such a major tranny malfunction from a mechanical failure would probably not be intermittent. I hope it is not due to the faulty wire harness problem - I inspected the wires in several locations under the hood and no signs of dry or cracked wire insullation.
Please help - I hate not being able to trust this thing!
95' Contour SE ATX - Killed by rogue whitetail 97' Cadillac Catera 98' Expedition XLT 4x4
#430040 09/06/02 02:52 AM
Check your Transmission Shift Position Sensor.
It is on top of the transmission, right below the airbox.
If this goes bad, your transmission will act up as you described.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#430041 09/06/02 03:13 AM
Yup, what RoadRunner said. There are two names for the sensor - I think the other one is "Transmission Range Sensor"?
'98 GL V6/MTX (Plenty of mods... in my basement) '88 ST165 (mild mods, stock 8psi)
#430042 09/06/02 12:56 PM
That sounds reasonable since shifter position seems to have no effect on the problem (if I shift from D to 2 or 1 it makes no difference). I haven't looked at it yet (I'm at work and it's pouring rain outside) - any tips for replacement. I do have a Haynes manual, so I'll see if it's in there.
Thanks!!!
#430043 09/06/02 02:12 PM
[selector lever position sensor] Its in my Haynes manual. page 7b-2. It tells you how to install, remove and adjust the switch.
seems very simple.
I feel sorry for the people who don't drink. When they wake up in the morning, thats the best they're going to feel all day - former President Lyndon B. Johnson
#430044 10/09/02 05:35 PM
To close this issue out - I replaced the transmission position sensor and the problem is gone. The sensor was $28 at the dealer and took about 30 minutes to install. The Ford tool mentioned in the Haynes manual is not required - there are aligment marks on the sensor.
Thanks for your help guys - this would have been one of those nasty intermittent problems that might have taken repeated trips to a mechanic to fix.
#430045 10/09/02 06:05 PM
man you guys are great. I can't believe you solved it that quickly.
you all deserve a pat on the back! I award your great efforts!
97 T-Red LX ATX pre98 CF SVT front,SVT rear/side skirts FSVT wheels Custom Front Ford Logo (body Colour) 35% tint all around with sun visor WP With Metal Impeller? Elky Grills CTA Intake CTA Custom Dual Exhaust
#430046 10/09/02 06:05 PM
#430047 10/09/02 06:30 PM
u thanked them twice, must have been a really bad problem.
#430048 10/09/02 07:04 PM
naw my connection died and I refreshed and tried sending it again. Lol
I had no problem, but I'm glad that I can come here and get help!
