Page 2 of 2 1 2
#429304 09/05/02 01:21 PM
Mine has been badgless from day one. Looks better that way.
'03 Saab 9-5 Aero
#429305 09/05/02 01:45 PM
I
I
Ditto man
#429306 09/05/02 02:03 PM
i think i am going to take them off. now the only question is how to do it without hurting the car.
1998 Sport Contour, A4 2000 WS6 Trans Am, M6
#429307 09/05/02 02:56 PM
use fishing line to wedge under the badges.. pull back to raise the edge enough to grip with your fingers.
Use hands to pull the rest off. (being sure to spy underneath for any faded paint/clearcoat overspray, etc, that you may not could hide, if uncovered..)
If there is anything that you don't like underneath, put it back on, unless you plan on repainting anyway.
if not, pull it off, slowly.
Use GooGone, or WD40, etc, to loosen the leftover gunk and rub it off with a wrag-wrapped finger.
Be forewarned, the appearance of blisters is common, and mostly unavoidable.
The same steps apply for the door ding strips..
Ray
#429308 09/05/02 04:25 PM
easiest way is to do this when its arm outside, or heat them up with a blowdryer. then squirt GooGone on them and let it soak in. Then use fishing line or a credit card to wedge the badge off. Pull the rest off my hand. Paper towels and GooGone can be used to get the rest off. Make sure you re-wax or polish the area after you're done because GooGone takes off that protective coat.
99 SE Sport SilverFrost MTX 01 F4i Red/White My mom says I shouldn't talk to conservatives.
#429309 09/05/02 05:15 PM
E
E
I went for the old SHO look...body colour. Still have to do the 24V badge.
#429310 09/05/02 05:32 PM
I'm badgless and dingless, it looks so much cleaner. I love the look, Now I want to try to find a set of SE side skirts
www.ChicagoCEG.com 2006 White Grand Prix
#429311 09/05/02 09:49 PM
Take them off. While your at it pop out the Ford emblem and get one of Nyceboi's emblems.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
#429312 09/06/02 12:35 PM
They look so much better without the Badges.. They are easy to remove.... I used my Finger nails.... But you can ust a Fishing String and WD 40 Worked good for the Adhesive or you could use Meguiars 3 Step Cleaning wax system.
John Was 96 Contour Zetec RIP Now 2001 Chrysler 300M.... I Will Have Another Soon... I AM NO TRADER......
#429313 09/06/02 11:17 PM
i did it. took about an hour, got them clean right off. it does look alot better. i would repost the pics, but they look just like the photo-shop pic. hehe. so look at that one and imagine its not photoshop.
Page 2 of 2 1 2
