Title says it all.
IIRC someone was going to try them out.
My car looks like a 4x4 with all the weight reduction. Plus is very soft and the lift & dive is just terrible. (front end lifts a good foot on acceleration!)
I'm definitely going with a matched set so this setup may be an alternative over the BAT setup.
I just recently drove a car with the BAT setup and it's awesome. Very flat, responsive, and predictable! Now mine feels even more floaty... ugh...
"All the weight reduction"?? Do tell us more ...
98.5 SVT now gone ... new wheels = 2005 330i
try a search, it's in here somewhere because I asked about it the first day the site came back up
Just before change, there was a post stating that the setup did work on our cars. The kit yielded approximately a 1" drop all around on a "Sport" contour. I believe Terry Haines said that he would be selling the kit in different packages: strut and spring kit, strut and spring kit w/mounts, strut and spring kit w/mounts and camber plates. I believe the kit did not come with the Koni yellows (adjustables), but with Koni Reds(non-adjustable).
1998 Silver Frost SVT Purchased 01/10/02 Mods so far: -Fidanza aluminum flywheel -Clutch upgrade -Clarion ProAudio system, DSP, 13 Band EQ -Autolite Titanium Plugs
Originally posted by DemonSVT:
Title says it all.
Flat, Responsive, Predictable, hugh, thanks Greg, exactly what I needed to confirm my descision to get the BAT Kit, the evidence files have been filled
PERFORMANCE PARTS for the TOUR click here:PXRACING Homepage email:pxracing@aol.com
Nope, comes with Koni Yellow adjustables.
In that case I think i'm going to reconsider this kit when I upgrade my suspension.
Dropped 55-60lbs worth of battery stuff & metal brackets for a 13lb battery. (-45lbs)
Dropped precats, stock Y, 1 heatshield & metal brackets for MSDS Headers & y-pipe (-40lbs)
A bunch of miscellaneous underhood parts (-5lbs or so)
There's atleast 90lbs off the front end.
Lost maybe 5-10lbs going from stock exhaust to custom exhaust and a couple more for miscellaneous parts and the aussie rear bar (10-15lbs more)
I feel I'm forgetting a few things???
I thought I had added it up to around 120lbs, but ~100+lbs is still great IMO. Also my weight distribution should be down to 60/40 or better. Another nice bonus for handling.
My goal at first was to be under 3000lbs. I'm now most likely under 2950lbs when I drop all the trunk related items & run at half a tank. Not too bad considering I have a sunroof (+40lbs)
However the ride height has come up at least an inch! No kidding! Comparing my car to Warmonger's with the BAT kit & SVT Focus rims (17") it looked like my ride height was 3-4" taller! I can fit my hand between the tires and the wheel well. Sideways!
W
W
Demon, you're not gonna be running your car against the Grave Digger are you? j/k My car weighed in at approx. 2,875 before Aussie bar, and MSDS install. This was with 3/8 tank of gas, Dyna-Batt, no spare/jack, and 17" Superlegerra's. Since the headers the car feels like it has as much front end lift @ wot as my friends big block 70' Nova. That's with an Eibach pro'kit!
2002 ZO6...462whp/410wtq pretty darn fast!11.70 @ 122 silver/black 2006 Trailblazer SS(wifes car) silver/black 2000 SVT-Turbo-sold silver/blue #1699/2150 13.83 @ 102.82 on 5psi 13.51 @ 107.56 on 8psi
Page 3 of the group buy,not any interest,check Mike Sidels car at www.seicoracing.com he has it fitted and 'track tested'....
