Originally posted by DemonSVT:
Originally posted by 2redtours:
The dealer used a slightly too-strong antifreeze mix.
Too much antifreeze versus water would cause the car to run hot. Water is a much better coolant (transfers heat better) than Anti-Freeze is.
Anti-freeze is used so the mixture doesn't Freeze. As an added bonus it contains an additive package to prevent corrosion.
Sorry but I have to partially disagree.
Ethylyne glycol both lowers the freeze point *and* raises the boiling point, as well as changing the heat transfer properties of the water. If you run straight antifreeze, the car will simply not warm up properly. I know this from experience in my old Ford Fiesta (not a Festiva, mind you, a real Fiesta, the first FWD Ford!) that had the thermostat go bad (stuck closed!). I did an on-the-road repair, and refilled the cooling system with straight antifreeze because I had no water available. The car ran cold until I partally drained and refilled the cooling system to get the mix right (note: it's much easier to get the mix right in a jug than in the car).
All moot, though. The best way to tell if the antifreeze mix is too weak or too strong is to test it with the correct tool and adjust from there.
Running too cold can accelerate engine wear, and decrease gas mileage too. As long as it's in the "normal" range, you should be fine. Keep an eye on it in the winter, though.
