Posts: 5,296 |
I remember reading a post about BAT ran out of the Control Arms with horizontal bushings? Anyone can confirm this?
Posts: 3,419 |
I can. You can call and see if they have any more; this was early May when I was trying to get some.
Posts: 5,296 |
Oh well... I guess I'll have to pay $30 more and get them from Bill Jenkins or Fordpartsonline.
Posts: 539 |
Are the horz bushing type control arms pressed on or can they be switched easily. Mine are completely detorated
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 3,419 |
Originally posted by jiako: Are the horz bushing type control arms pressed on or can they be switched easily. Mine are completely detorated The bushings aren't replaceable without getting a whole new control arm. The arms aren't pressed on, but I certainly don't call their replacement easy. Read about my experience
Posts: 34 |
If you're just worried about bushings, SHO-Shop offers quite a few urethane bushings for Contour suspension. You may want to try them.
Posts: 3,419 |
Originally posted by Jeff: If you're just worried about bushings, SHO-Shop offers quite a few urethane bushings for Contour suspension. You may want to try them. Originally posted by PA 3L SVT: The bushings aren't replaceable without getting a whole new control arm ... at least on the 95 - midyear 98 (built up to Dec 97 give or take) models.
Posts: 539 |
So are you saying theyare not replacable on the 95-98 or are they replacable.
Posts: 4,528 |
No one has replacement bushings for the control arms. You have to buy the entire arms.
Master P
Master P
Posts: 5,455 |
So I can get some bushings for my 96 from BAT?
