#428717 09/04/02 04:55 PM
A friend of mine has a 01 focus with eibach springs and struts, and falken tires. Other than that not much else. I have a 98 SVT Contour with KONI struts on all four corners, ground control coilovers, BFGoodrich g-force kdw tires, sub-frame connectors and the BAT rear sway bar. On the street it seems like its harder for his car to break loose than mine. Have I missed something, or are the focuses just designed better for handling. Thanks
Ground Control Coilovers Koni Adjustable struts Sub-frame connectors Slotted rotors Carbon Fibre pads Stainless Steel Braided line KKM Intake Pro-Flow Mass-air Meter 22mm rear sway bar Polyurethane motor mount inserts
#428718 09/04/02 06:46 PM
b0x @dm1n
b0x @dm1n
Any number of factors could contribute to this "feeling" but more than likely it's in your head. Nothing personal it's just that like a Butt-Dyno you aren't an acurate measurement. A couple factors could be that the Contour weighs more and has more power. It's hard to break anything loose with 130 some odd HP.
-Andy
Andy W. The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
#428719 09/04/02 08:27 PM
If you have Ground Controls have the 'X' weights checked and set up correctly.....then you can get him!!!!
#428720 09/04/02 08:32 PM
b0x @dm1n
b0x @dm1n
Terry,
Who would likely have them? Alignment shop?
-Andy
#428721 09/05/02 12:58 AM
2
Terry is right, with GC you need to do corner weights to dial the car in. Terry also noted some nice sites on this subject in the past.
see: http://www.grmotorsports.com/cornerweight.html
Anthony B. Davis 2Deep2 Silver SVT 2002 IASCA SQ Ult Ama 601+ World Champion runner up 2002 SLAP dBQ Champion 2000 USAC SQ World Champion 2002 USACi SQ World Champion
#428722 09/05/02 03:39 AM
Terry's got that one right.
Although if the Left/Right balance is good (tape measure from fixed point on car down to center of wheel, or flat floor) the car should be pretty close to good, as far as a normal driver can percieve on street tires anyways.
I find Front/Rear balance is where the game is played. You can turn the Contour in anything from an understeering behemoth to something so tail-happy you'll shiz your pants if you ever have to make an emergency maneuver.
I found my balance with a little experimentation and my car is very neutral. Note that I removed my front sway bar, and am running the stock SVT one in the back.
I dare any Focus to follow me around a curvy track on street tires.
#428723 09/05/02 07:47 PM
if you mean that your back end is breaking loose (AKA oversteer) you may try a SMALLER rear anti-sway bar.
You can also play with your tire pressures to fine tune the package.
