Posts: 21,653 |
My 96 has the fiberboard or whatever it is under all of the trunk carpeting except of course for the flexible parts on the sides,,, though ford may have discontented some of this material in later years.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 951 |
Here's a picture story for everyone who needs it (like me) This is the rear of the trunk, behind the wheelwell. I pinpointed this as the leak spot because of the water focused there (isnt that strange?  ). This discovery was made after I locked my girlfriend in the trunk and poured water on it Remove the grey carpet covering or whatever, and you see the vents talked about throughout this post. Here's the vent close-up. See the water traces under it? It was loose, but the other side wasnt and there was no sign of damage. This is why it leaks. This was supposed to be around the vent on the outside of the trunk under the bumper, but it was loose, so i just pulled it off because i am not crafty enough to glue it back. so0o00o Originally posted by seven777svt: BTW use common sense to repair/replace/fix these, very simple. Later
Common sense would tell me to use silicone on the inside of the trunk around the vent, to permanently seal it. Anyone agree, or does anyone suggest anything else? I want to use some brownbread in my trunk (or something like it, even a spray can), but not until this is fixed. It made my current dual 15" box soggy, and the condensation was running off onto my amp. Good thing the terminals are covered on the bottom of the amp.
Thanks to everyone on this board for their help on my annoying problem
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Posts: 1,110 |
I believe I used silicone to seal around mine. Worked great. The foam around my passenger side vent crumbled so I had little choice.
'01 Escape XLT V6 on S100
CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup
'00 SE Sport ATX
Posts: 1,228 |
Just in case some else has a leak, my leak war from a loose factory spoiler. The nuts that hold it down are under the rubber bumpers. I drilled out the rivets, tightened the nut, put some crazy glue on the nut so it won't work loose. No more leaks. If you have a spoiler, check those mounting bolts.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 951 |
after all of that silicone..... its the friggin tail-light. when you open the trunk, at the top of the tail light there is a small gap (on each light). water goes in, and most drips down to the concrete, but some runs to the vents and through, and some through the seals inside of the trunk from poor manufacturing. Could I put silicone in these holes above the tail light? if you guys need pics, i can provide
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 328 |
My leak was around the taillight. I took the light off, cleaned off the mud that had acumulated around the foam gasket and siliconed it back into place. It's been fine since. The vents have never been a problem (so far).
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
Posts: 951 |
so does anyone have tips on how to remove the tail light?
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 4 |
Hi guys, my leak seems to be coming from the rear license plate holder assy. When I open the trunk, water runs out of the driver's side back-up light socket. Any ideas?
Thanks, Dave
'98 Mystique LS (wife's car)
2.5 V6, auto, no ABS
Green w/Tan leather
Contour Sport rocker panel covers
2000 SVT Contour wheels
Posts: 101 |
I had the same problem - intermittent leak inside the trunk. The rubber gasket around the taillight had rotted away. I just got a cheap generic rubber gasket at autozone and replaced the rotted one with it.
I don't remember exactly what I did to remove it, but there are some nuts on long screws that hold the taillight on. I do remember it wasn't very difficult to remove.
Steven
Steven
'98.5 SVT
DMD, K&N, Magnaflow res, Falcon floormats, electrochomatic rearview mirror and other little goodies
Posts: 951 |
I know those screws.... can you imagine I had my amp grounded to those screws? HA! So you all are saying that dirt buildup around the inside of the tail light would cause water to run down the side into the vent eh? I'll take the light off and let everyone know how this works out...
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
