Page 4 of 5 1 2 3 4 5
#428490 12/27/03 06:04 AM
My 96 has the fiberboard or whatever it is under all of the trunk carpeting except of course for the flexible parts on the sides,,, though ford may have discontented some of this material in later years.
#428491 12/29/03 05:23 PM
Here's a picture story for everyone who needs it (like me)
This is the rear of the trunk, behind the wheelwell. I pinpointed this as the leak spot because of the water focused there (isnt that strange? ). This discovery was made after I locked my girlfriend in the trunk and poured water on it
Remove the grey carpet covering or whatever, and you see the vents talked about throughout this post.
Here's the vent close-up. See the water traces under it? It was loose, but the other side wasnt and there was no sign of damage.
This is why it leaks. This was supposed to be around the vent on the outside of the trunk under the bumper, but it was loose, so i just pulled it off because i am not crafty enough to glue it back.
so0o00o
Originally posted by seven777svt:
BTW use common sense to repair/replace/fix these, very simple. Later
Common sense would tell me to use silicone on the inside of the trunk around the vent, to permanently seal it. Anyone agree, or does anyone suggest anything else? I want to use some brownbread in my trunk (or something like it, even a spray can), but not until this is fixed. It made my current dual 15" box soggy, and the condensation was running off onto my amp. Good thing the terminals are covered on the bottom of the amp.
Thanks to everyone on this board for their help on my annoying problem
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
#428492 12/29/03 05:37 PM
2
I believe I used silicone to seal around mine. Worked great. The foam around my passenger side vent crumbled so I had little choice.
'01 Escape XLT V6 on S100 CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup '00 SE Sport ATX
#428493 12/29/03 09:15 PM
Just in case some else has a leak, my leak war from a loose factory spoiler. The nuts that hold it down are under the rubber bumpers. I drilled out the rivets, tightened the nut, put some crazy glue on the nut so it won't work loose. No more leaks. If you have a spoiler, check those mounting bolts.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#428494 12/30/03 06:54 PM
after all of that silicone..... its the friggin tail-light. when you open the trunk, at the top of the tail light there is a small gap (on each light). water goes in, and most drips down to the concrete, but some runs to the vents and through, and some through the seals inside of the trunk from poor manufacturing. Could I put silicone in these holes above the tail light? if you guys need pics, i can provide
#428495 12/31/03 05:18 AM
My leak was around the taillight. I took the light off, cleaned off the mud that had acumulated around the foam gasket and siliconed it back into place. It's been fine since. The vents have never been a problem (so far).
- Jim Our yardbirds: Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
#428496 12/31/03 02:32 PM
so does anyone have tips on how to remove the tail light?
#428497 01/01/04 04:16 PM
Hi guys, my leak seems to be coming from the rear license plate holder assy. When I open the trunk, water runs out of the driver's side back-up light socket. Any ideas?
Thanks,
Dave
'98 Mystique LS (wife's car) 2.5 V6, auto, no ABS Green w/Tan leather Contour Sport rocker panel covers 2000 SVT Contour wheels
#428498 01/05/04 06:43 PM
I had the same problem - intermittent leak inside the trunk. The rubber gasket around the taillight had rotted away. I just got a cheap generic rubber gasket at autozone and replaced the rotted one with it.
I don't remember exactly what I did to remove it, but there are some nuts on long screws that hold the taillight on. I do remember it wasn't very difficult to remove.
Steven
Steven '98.5 SVT DMD, K&N, Magnaflow res, Falcon floormats, electrochomatic rearview mirror and other little goodies
#428499 01/05/04 11:45 PM
I know those screws.... can you imagine I had my amp grounded to those screws? HA! So you all are saying that dirt buildup around the inside of the tail light would cause water to run down the side into the vent eh? I'll take the light off and let everyone know how this works out...
