Originally posted by CrankyCrankPot: 543 - Fuel Pump Circut
P0543??? I don't see no stinkin' P0543!  Do you mean P0453 (Fuel Tank Pressure Signal circuit Input above maximum)? If so, then the following is from the Ford TSP: HX33 DTC P0453: CHECK FOR HIGH FTP SENSOR VOLTAGE
Diagnostic Trouble Code (DTC) P0453 indicates that Self-Test has detected a FTP circuit input above the maximum.
Possible causes: -- FTP open. -- FTP short to VREF or VPWR. -- VREF shorted to VPWR. -- SIG RTN open. -- Damaged FTP sensor. -- Damaged PCM.
* Key off. * Connect scan tool. * Key on, engine off. * NOTE: FTP sensor input with no pressure/vacuum on the fuel tank (fuel filler cap open or not open to atmosphere) is 2.37 to 2.97 volts.
Access FTP V PID.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
