Posts: 274 |
i was surfing the channels at like 2am...trying to find something to watch...and i found TNN having a advertisment commercial for that Tornado Gas saving system...they say it gives you better gas milage and a 5-20hp boost?? its only a round peice of metal with slots in it..anyone tryed it?? i think they are bs'in everyone into it, but i might be wrong?
Teal|'95 'Tour GL|75k| 16V 2.0|Rebuilt ATX|
Factory Euro Mod's (Ordered in Dec '94 From Holland)-|Larger Radiator, Oil pan, Fan, Tank..little things make a difference|
Mods to Come-|Open air w/K&N filter|New Exhaust|Pre-98 Bumper|Trim Kit|Fox 2 Rims|& More..|
Posts: 1,355 |
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 229 |
If it worked it would be stock on all new vehicles. It's a load of crap more commonly refered to as "Snake Oil" in these here parts.
99 CSVT Green/Tan 13,700Km # 84 of 2760
For Sale 96 Contour GL 2.5 ATX 120,000Km K&N Air Filter Mobile 1 E1 SVT Wheels & BFG G-Force Rubber Aluminum Painted Front Grill
Posts: 1,861 |
SNAKE OIL
COVER YOUR TAIL AND RUN!
Jim Johnson 98 SVT
Posts: 816 |
for most applications a TORNADO will HELP. The 70+mph winds created by it will help to push you along, or in many cases pull you along, just watch out for the dreaded flying car syndrome associated with the use of a TORNADO for power boost. Most drivers do not have the skills to handle a TORNADO, so test out your first TORNADO until you get good, then use TORNADOS anytime you please.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 137 |
my friend wanted to buy one, i told him its a piece of crap and to save ur money, so we started to debate, i made a topic on it here....
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=33;t=001245
that should help ya out, theres a lot of good info on it
96 Contour Sport Mostly Stock CTA Intake(CAI) JL Audio & MTX Setup
Posts: 1,445 |
i laughed and watched that mis-infomercial earlier...the host mouths the words of testimony from the customers....he looks like he's puttin on the hits
and why if this thing affects air intake it takes 2 or 3 tankfuls before u see any improved mileage...shouldn't it show up right away?
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 229 |
Originally posted by gdub520: and why if this thing affects air intake it takes 2 or 3 tankfuls before u see any improved mileage...shouldn't it show up right away? You would think. Run and don't look back.
Posts: 147 |
I try not to believe or dismiss anything until someone actually tries it with an application relevant to me.
Some of the reasons it would work make since, and some of the reasons it wouldn't work make since.
Has anyone with a Contique actually tried one of these, and done real before and after test of HP/Torque, gas milage?
Posts: 460 |
Originally posted by gdub520: ...and why if this thing affects air intake it takes 2 or 3 tankfuls before u see any improved mileage...shouldn't it show up right away? I think that the manufacturer is setting the requirement that you have to allow this period of time to allow it to adjust your computer... On the other hand, it buys them time so that the money-back gaurentee time is burned and you are left "screwed" out of your hard earned dollars. It is called a "Catch-22". Typical bait-and-switch marketing ploy. "Pretty Sneaky Sis"(ala Connect Four Commercial circa 1980)!!!
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
