Posts: 7 |
i bought a stock 98 svt and I plan on spending $2000 on modifications. I need some advice. What would you do?
Posts: 1,444 |
intake, exhaust, b&m shifter, suspension (groundcontrol & koni's)
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 79 |
BAT suspension - ~700.00 MAF with k+n on the end - ~300.00 y-pipe - ~250.00 exhaust - ~650.00
Old - 95.5 SE with lot's of mods. New - 98 Black SVT with few mods.
Posts: 1,201 |
What do you want show or go?
If it's true that we are here to help others, then what exactly are the others here for?
Posts: 316 |
Venom 2000, BAT Suspension Kit, and DMD.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 1,732 |
- Tint - $150 - B&M - $150 DIY - BAT kit - $700 + install - intake - $100 DIY - exhaust - $600 DIY
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 7,329 |
LSD (Quaife), clutch (Clutchmasters), flywheel (SHOShop), & labor (Terry) So where's my $2000 now...
Posts: 563 |
Originally posted by DemonSVT: LSD (Quaife), clutch (Clutchmasters), flywheel (SHOShop), & labor (Terry)
So where's my $2000 now... Don't forget about an upgraded shift tower!
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
Posts: 878 |
Borla, $600 K&N Drop-in, $50 (guessing, here) Superchip, $250 Koni struts, DIY install, and shop aligned, $700 Aussie Bar, installed, $200 Mintex A/F Brake Pads, $100 DMD, $100
Smiles, every time you drive to work, priceless.
"Function before fashion."
'96 Contour SE
Posts: 3,419 |
Originally posted by RogerB:
DMD, $100
Start there. You now have $1900 to spend. A DMD is an investment in your engine's longevity.
