#427602 09/03/02 02:20 AM
Does anyone know where is MRCI located on the 98 SE Duratec?
Thanks Sergey.
98 green SE duratec, SOLD, GONE but NOT FORGOTEN. 04 Silver STi, Lot's of Power, Some MODS
#427603 09/03/02 02:33 AM
H
H
Under the Duratec cover.
#427604 09/03/02 02:34 AM
Thanks man.
#427605 09/03/02 11:35 AM
What is the "Duratec cover"?
#427606 09/03/02 01:09 PM
The black plastic cover over the front cylinder bank and just in forward of the UIM.
#427607 09/03/02 03:54 PM
Is the IMRC the silver rectangular box under the black plastic cover and above the middle spark plug? The silver box I am talking about is attached by three screws.
#427608 09/03/02 05:20 PM
1. Is the IMRC the silver rectangular box under the black plastic cover and above the middle spark plug?
2. The silver box I am talking about is attached by three screws.
1. Yes
2. Yes; 3 bolts, 1 plug, & a cable
#427609 09/03/02 06:38 PM
Thanks.
I replaced my ignition wires yesterday and had to remove the IMRC to get to the front wires. When I removed it and move it, I heard something like a marble moving around inside. When I shook it, the marble sound continued to move back and forth. Is that normal?
What is the IMRC supposed to do?
#427610 09/03/02 10:42 PM
Webmaster
Webmaster
IMRC = Intake Manifold Runner Control
ie. it controls the opening of the secondary butterflies in the lower intake manifold.
Without a functional one, you won't get much power above 4K rpms.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
#427611 09/03/02 11:38 PM
If you shake the IMRC, is it supposed to sound like something is moving inside?
