Posts: 3,237 |
OK, the cost on the replacement pump (only) for the V6 Contour, the TTP-298, is $110.61c from V E Peterson (a pump supply company) their number is 1 800 537 6212, ask for Jim Brown if you want to order one.
Should have the pump in a week as they have to order it from Walbro as they didn't have it in stock.
Posts: 707 |
Nice... You'll be glad yo made the gusset cuts around the rear of the hole
Chad Williams chad5160@excite.com '99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
Posts: 176 |
Specs are as follows: Max Power Consumption @ 30Lph/270kPa = 50W Max Current Draw = 10.1A Nominal (NEW) = 8.49A Nominal Performance = 154Lph Min New = 125Lph General Test Condition = 12.0V/350kPA
Any way you could have your contact see if these are the same as a non-svt? 154 Lph sounds like a a lot, I don't think mine could put out that much. Thanks and nice work!
2000 Roush Cougar MTX MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Posts: 3,237 |
The only way I can tell you what your non-SVT pump is rated at is by YOU telling me the part number on your pump. So whip it out and check. I have a print dump with about 20 pumps on it, and I am pretty sure that it captures most pumps that ford uses for passenger cars.
Remeber though, the returnless pumps work "on-demand" so there is a good chance you pump is the same (for all V6's) In fact I think there is only two pumps for the CDW27 platform - Zetec and V6, regardless of engine code.
The pump will only delver as much fuel as the ECU tells it too. It doesn't mean that you get 155lph by using the above pump. These are TESTED ratings.
