Posts: 41 |
VTEC THIS
98 CSVT, 17 Focal F5's, Dynomax Bullet Resonator , , K&N Drop in,Formaly known as VTECTHIS
Posts: 869 |
IIRC, we're not supposed to use b+4's in our cars. However I could be wrong, I am only a lowly zetec'er. another suggestion.. you mentioned 4500rpms, and holding back.. sounds like it could be plugged cats or closed secondaries.
Turbocharged trolling around here somewhere.
Beat your wife, Potvin, beat your wife!
True Blue 06...err...07~LET'S GO RANGERS!!
Posts: 1,085 |
IMRC controller cause this.Mines fuped right now and falls flat at 5Krpm.No cel either.
I AM WE TODD IT
I AM SOFA KING WE TODD IT
Posts: 41 |
Originally posted by Journie: IMRC controller cause this.Mines fuped right now and falls flat at 5Krpm.No cel either.
How much is that to fix.If that was it would the check engine light come on.Also would it be covered under an extended warranty.
VTEC THIS
Posts: 1,228 |
You can check IRMC easily. CAr in neutral, E-Brake on, rev engine (by hand, under hood), you can see the imrc lever on the rod sticking out of the head move. No Move, NO good.
It's located under the Throttle body area..
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 1,085 |
I got one from BIll for around $100.It seems like it would definetly be covered under warranty.My check enginge light(CEL)came on when they first messed up,stuck open,but now there stuck closed and no CEL.
I AM WE TODD IT
Posts: 9,602 |
...and while you are testing the IMRC...
replace the crappy +4's!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,603 |
Bosch Platinum +4s are fine in my Duratec. I replaced the wires with Ford MotorSport wires at the same time I replaced the plugs. I have no complaints about them.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 41 |
Trust me I plan on replacing them as soon as I get the money.I plan on going with the autolites Double Plats #APP764.Is this a good Idea.
VTEC THIS
Posts: 41 |
Originally posted by Contouraholic: You can check IRMC easily. CAr in neutral, E-Brake on, rev engine (by hand, under hood), you can see the imrc lever on the rod sticking out of the head move. No Move, NO good.
I tried what you said and it moves when the rpm's get high is that normal or is it suppose to open as soon as I begin to rev the engine?
VTEC THIS
