Posts: 1,355 |
So I bought an SCA intake pipe to see what there like, I installed it on the SVT engine I have sitting on my garage floor. Everything connected but towards the botttom of the pipe there is a hole. I can't seem to find the pipe that connects to it. I have looked on CTAMotorsports and spmotorsports and it states on their intake pipes that the SVT has 4 connections, where as the standard V6 has only 3.
Can anyone provide close-up pics of where this 4 pipe comes from and goes too??? Thanks.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 424 |
Simon, the hole in the pipe is for the IAT sensor. Hope this helps.
2000 SVT silver/blue #1699 of 2150 14.793@94.88 Sho-Shop off road y-pipe for sale($75)
Posts: 1,355 |
Originally posted by wavrdr: Simon, the hole in the pipe is for the IAT sensor. Hope this helps. It depends, is there not an IAT pipe on a standard V6 (non-svt), On the SCA CAI pipe there are 3 connections at the top of the pipe near the TB, which I have 3 pipes connecting too formthe SVT Engine (the only e pipes I can see also), but towards the bottom of the pipe where the filter attaches, there is a hole. I have looked at the BAT intake pipe, and sure enough it has 4 pipes. So I know that a pipe is supposed to connect to this "hole" but I can't see which one! Driving me nuts! lol.
Posts: 1,445 |
the iat sensor connects to the hole...and whatever hoses on the svt inlet pipe connect to the top hose connections...
im not an svt owner but i play one on tv
that and the fact that i have an sca pipe sitting in my closet (well in front of me on the desk now) that i cant use because it wont fit with my atx case in the way
if u're trying to fit this pipe to a non svt they only 2 of the hose connections u will use (i think) plus the hole for the iat sensor...in that case 1 of the holes needs to be plugged up
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 36 |
Originally posted by gdub520: that and the fact that i have an sca pipe sitting in my closet (well in front of me on the desk now) that i cant use because it wont fit with my atx case in the way Are you saying that the SCA intake pipe will not fit our cars with the auto tranny? Or am I just reading it wrong. :rolleyes:
*99 Contour Sport SE*
-KKM Intake- -Res Removed- -Matrix blue headlights- -Custom Dual exhaust- -Mystery Mod- -Removed turn single reflectors- -Fog Light fix- -Pioneer Head unit-
Posts: 1,355 |
I don't think it fits as the ATX trans comes up higher in the engine bay then an MTX trans, This doesn't give the room needed for the SCA pipe + filter at the end. Just what I've heard anyway.
Posts: 1,090 |
Originally posted by Xtreme Csport: Are you saying that the SCA intake pipe will not fit our cars with the auto tranny? Or am I just reading it wrong. :rolleyes: [/QB] It was designed for the SVT, but will fit all MTX cars, it will not fit the ATX cars due to the size of the ATX.
Posts: 424 |
Originally posted by Simon96SE: Originally posted by wavrdr: [b]Simon, the hole in the pipe is for the IAT sensor. Hope this helps. It depends, is there not an IAT pipe on a standard V6 (non-svt), On the SCA CAI pipe there are 3 connections at the top of the pipe near the TB, which I have 3 pipes connecting too formthe SVT Engine (the only e pipes I can see also), but towards the bottom of the pipe where the filter attaches, there is a hole. I have looked at the BAT intake pipe, and sure enough it has 4 pipes. So I know that a pipe is supposed to connect to this "hole" but I can't see which one! Driving me nuts! lol.[/b]Simon, the lower hole is for the IAT sensor. You need to remove the rubber o-ring form the stock airbox, and fit it into the hole. Hope this helps.
Posts: 1,355 |
Yeah that's the one. I bought it off another CEG'er and it has the rubber ring in it already. So now I just have to "find" the IAT sensor pipe!
Thanks guys.
Posts: 13 |
there is no IAT sensor pipe, you stick the sensor straight into the hole like you stuck it straight in the stock airbox. ive had this intake installed on my car, standard duratec. you just stick the sensor inside that hole.
