Posts: 307 |
Originally posted by ElKy-8 months and counting: What about the black tour with the dark red flames. he cut a teardrop shaped opening in his fender. i cant find the pics, but they are out there. That's not true Ram Air. The cutout doesn't actually interrupt the regular airflow with it's own intake scoop. I've got photos of it, though. EDIT- Nevermind. The man with the car posted his links w/ pics.
'99 Contour SE V6 w/MTX (Black Clearcoat) '02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Posts: 1,701 |
I've experimented around with hoses to bring cold air in from the bumper area and I think it's pretty effective, especially for mid and upper end pull. My setup runs 2 1/2" shopvac hose up through the fenderwell and into the inner cone of a S&B powerstack filter. When you consider you can do this mod for under $25, it's well worth it. There are some older pics im my sig/link.
Posts: 307 |
Originally posted by tw0wheelin: I've experimented around with hoses to bring cold air in from the bumper area and I think it's pretty effective, especially for mid and upper end pull. My setup runs 2 1/2" shopvac hose up through the fenderwell and into the inner cone of a S&B powerstack filter. When you consider you can do this mod for under $25, it's well worth it. There are some older pics im my sig/link. I did the same thing, but I actually disconnected the hose because I "felt" like I lost some bottom end torque. Almost felt like turbo lag. But when it got over 4000 RPM, it was a monster all the way to redline. I did leave the hose in place to dump cold air directly in front of the air filter, though. I think it's doing a good job...
Posts: 897 |
Hey, CAM2, nice pics. Props on your creativity.
1998 T-Red CSVT (1492 of 6535) Born on 5/30/97 KKM 4.6L TB with custom "Throttle Optimizer" Bassani Exhaust NP-Tuning Sniper Intake Pipe Fog Light Mod with 885's Clear Corners Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
Posts: 1,244 |
CAM2 at night do you get alittle heat soak from your headlights generating heat?
Posts: 816 |
tw0wheelin: did u do u'r grill urself? who did you do it? I want to do the exact same thing. also how much better do poly sway bar bushings make the ride?
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
