Page 3 of 3 1 2 3
#425654 09/10/02 06:13 PM
Thanks for looking Rara.
Yes, length i measured is the whole bolt. Do you know what the thread pitch is? (1.25?) That is something I forgot to check when i had the bolt off. I'm try to find an aftermarket SS one that is a Grade 10 in that length.
Silver 98.5 SVT 5/19/98, 6023 not quite stock. 04' S2000 Silverstone Red/Black interior
#425655 09/12/02 12:18 AM
Cool Toe Chris
Cool Toe Chris
Brian found some bolts for us. Bill is looking into prices and availability of the parts. Stay tuned!
Chris NJ 98.5 SVT Silver Frost
#425656 09/16/02 07:12 PM
Cool Toe Chris
Cool Toe Chris
Originally posted by SF-SVT:
From what I have measured, I'd need a 0.118" spacer. (~3mm) I've ordered the spacers from Todd. I have ordered extra shims to make 0.110, 0.115, 0.120, 0.125. I'll try the 0.115" first to see how that fits.
Just remember this is what I have found on my year car. Just be careful, it may be different for other year cars!
So, Brian has found and Bill has sourced the longer bolts, 35mm thread length. I just found a machine shop that can make the shims out of SS, I'm not sure if grade 10 is good enough, but the owner/machinist will let me know.
SF-SVT, let me make sure I understand this:
0.110? = 2.794mm
0.115? = 2.921mm
0.118? = 2.9972mm IDEAL
0.120? = 3.048mm
0.125? = 3.175mm
I asked the shop to make me these shims and Bill may/will be ordering enough sets to make a 'grab-bag' of shims, which he will include in the purchase of the rotors/calipers, at an additional cost. From what I was told to expect, about $10-$15, since they will be custom made, if they can source the proper material.
I would prefer to only use 1 or even 2 shims, for safety's sake. Let me know and I can ask them to go ahead with the shims.
#425657 09/16/02 10:13 PM
Yes the 0.118" or 0.120" would be fine.. that would be pretty much on. I think added the rest of the shim to the caliper to make 0.130" That put a little more space on side of the bracket where the rotor is facing the wheel. (outside face of bracket?) There was that slight 'excess' of material on the 'outside' of the bracket i wanted to clear.
Ok that will be 10 - 15 buck extra for a set of shims? not one?
Ok thanks
#425658 10/02/02 03:22 PM
Any updates on this?
#425659 10/02/02 06:21 PM
Cool Toe Chris
Cool Toe Chris
Sorry, still waiting on the longer bolts from Bill. I will update once I get them on the car.
#425660 10/06/02 08:57 PM
I saw this in the gallery:
In reply to:
Description: Test fit of 17" wheel on FSVT brakes
This is a mistake right? The FSVT brakes will fit under a std 16" CSVT wheel right?
Thanks
Geoff C. Turner 99 Black SVT -mine 99 Blue SE V6 ATX -mom's 96 Black SE MTX -sister's All with 278mm front rotors
#425661 10/06/02 09:45 PM
TGO Offline
In reply to:
Thanks
yes they will
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#425662 10/08/02 04:05 PM
If you read all the posts in this, yes they will fit, but require shimming of the caliper mounts to have clearance of the steering knuckle assembly. I think that's where the issues are...
JasonS 2000 SVT #1119 Go: SHOshop Intake & y-pipe, Brullen exhaust, Eibach springs, EBC TurboGroove rotors, Corbeau seat, TRW 5pt Harness Show: Knauberized, Clear corners
Page 3 of 3 1 2 3
Moderated by  Andy W._dup1
