Posts: 311 |
I've seen many engine bay pics with the battery missing. Where did it go? Do Mondeos have a different battery location or something? I've tried to figure it out but I'm puzzled.  I'm sure there's a how-to or something I missed on search... I'll get my chops busted for sure! I'd like to move mine if possible. Any help appreciated!
1998 Contour Sport V6, Black *Cold air induction *Powdercoated intake manifold (more powdercoating coming soon) *Blue headlights, foggies, and signals (no reflectors) *CEG stickers & removed door moldings -------------------------------- 1994 Ford Aspire 4-door, looks like a big egg *64 hp 4-cyl *5 speed *"13 steel rims with go-cart tires *74 mph top speed *I'm going to auto-x the thing (but not compete)
Posts: 138 |
Posts: 93 |
you can get a relocation kit from summit
GO WINGS! 99 SVT Silver w/ Blue Stripe with some mods. mike4420@comcast.net "To each his own"
Posts: 60 |
you can use welders cable fom autozone if youd like. leave the starter selenoid up front and make sure you have a 2 (0) ground cable.
1985 SVO: 4 cylinders, 5 gears, 20 PSI 1998 torredor red SVT contour: #3705 of 6535 need info on your SVTs service/recall/warranty history? e mail me...
Posts: 581 |
Hey Don, DO you a Mustang SVO???
-Mancho- cars name is Connie 99 Silver Frost SVT #1986 k&n filter with cut out box true duals w/ flows  Ground Controls with 17's mille miglia ... Hightower headlights 15.4 at 90.29 at Milan dragway before the true duals
Posts: 376 |
Any opinions on what the best kit is?
~Shawn Clone~
1999 SE Sport V6 MTX Silver frost/Midnight Blue BAT Euro Handling kit, SCA Cold Air intake, painted dash/calipers, Elky's mesh grille, bulitt fuel door,B&M shifter, ES motor mount inserts, OMP front strut tower brace, newest mod- HPP rear strut tower brace ...coming soon, Aussie Bar Possabilities in the works: Custom CAI, Polished stainless shifter cover plate
Posts: 816 |
You just through u'r battery in the passenger seat, then solder jumper cables to the battery cables and run it to the battery. Now you have a driving companion that corrodes and always has some acid you can share. Try a relocation kit from various companies.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 878 |
Originally posted by NorMich99SE: Any opinions on what the best kit is? I'm pretty sure the "kit" consists of basically a battery box (much like the one on your sump pump battery backup, if you have such a thing) and the necessary cables. They are probably all about the same, so I'd go for best price. Unless, of course, you plan to do club racing, or just want the metal box that club racing requires. Summit Racing sells both kinds, and their pricing is usually reasonable, but you can check around.
"Function before fashion."
'96 Contour SE
Posts: 1,152 |
Taylor makes a nice kit. I have it. So far so good.
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 110 |
what would be the pros and cons of a battery reposition kit?
Would the wires be travelling in through the interior? And what would the minimum gauge be? Any serious hazards to this?
