Posts: 73 |
Well i removed the Resignator and the Muffler, now my car sound god awful , you talk about RASSSPING...WOW .......i get some awful looks from people....OK now where the resignator WAS can i add a Cheery Bomb in there and quiet down the rasping ?
Thanks.....
99 Contour Sport 24 valve Gutted Cat,Resignator Removed 5% Tinted Windows, Side strips removed
C10N@yahoo.com
Posts: 1,355 |
Well yeah, I would think it would sound bad if you remove BOTH the res AND the muffler. Normally its one or the other, but not both. I would get a high flow muffler and put it where the res was. Then you should be fine. Cherry bombs aren't that good and don't last long (burn out).
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 73 |
Ok maybe a High Flow "Magnaflow from Discount Auto for 39.00 ? and will that flow MORE then the Resignator did ?
C10N@yahoo.com
Posts: 422 |
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 1,355 |
That sounds good. Actually, anything would flow better then a stock res!! hehe. Can't go wrong with magnaflow.
Posts: 311 |
I agree with these guys. Anything with glass in it is going to burn up in no time. After that it back to the 'ol 'rock in a pop can' rasp! Magnaflow is a good choice.
1998 Contour Sport V6, Black *Cold air induction *Powdercoated intake manifold (more powdercoating coming soon) *Blue headlights, foggies, and signals (no reflectors) *CEG stickers & removed door moldings -------------------------------- 1994 Ford Aspire 4-door, looks like a big egg *64 hp 4-cyl *5 speed *"13 steel rims with go-cart tires *74 mph top speed *I'm going to auto-x the thing (but not compete)
Posts: 401 |
I did glasspacks last week- unhappy with it and going with magnaflow + glasspacks this week . Where is it that they are $39? As far as burning out...the things cost 10-15 bucks (glasspacks) no big loss there. It might be possible to put a glasspack in the res spot and have pipe run back to the back. I am trying that while I look for a magnaflow I can afford.
99 SE Sport 2.5 Duratec Spruce Green Metallic.. Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Posts: 149 |
I'm just about ready to replace my resonator on my 98 SVT with a rather large glasspack....... Has anyone done this??? I want some volume but also a nice tone........seems like a cheap enough mod seeing how I already have the glasspack Any Thoughts?? I still have the stock SVT mufflers intact.... Opinions please!
THanks, Jason
Posts: 401 |
might sound decent since you have the stock mufflers......i have an SE with glasspacks in the res spot and muffler spot-- sounds decent but not what I want.
Posts: 583 |
Originally posted by CitatioN10: Well i removed the Resignator and the Muffler, now my car sound god awful , you talk about RASSSPING...WOW .......i get some awful looks from people....OK now where the resignator WAS can i add a Cheery Bomb in there and quiet down the rasping ?
Thanks..... I'd just get the Brullen
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
