Here we go!!! Each and every comment is Mystique's writing.
The Mystique is coming someday...? when he takes new photos.
I'm going to bed now.
1990 Pontiac 6000 Special Edition All-Wheeled Drive, Brilliant White Clearcoat with Stone Gray 2-tone heated Connolly leather bucket seats
Tach/Speedo/Odometer gauges, pic taken long ago, it currently has 18X,XXX on it now. Can be switched between Miles and Kilos
Gauges: Fuel, Oil Pressure, Volts...
Climate Control/Delco Bose stereo
Diagnosis system: AWD moniter, air ride moniter, low fuel, washer fluid warnings, blown highbeam/lowbeam/tail/brake/turn signal indicator, service reminder, door open, hood open, trunk open, security, tire pressure, engine moniter, oil moniter, trip odometer (Can be switched between Miles and Kilos)
Air pump/Air Ride Control, can be used to blow up flat tires, balls, anything...also controls the rear shocks
First Aid Kit, spot light, air hose, alot more junk...
steering wheel radio controls, volume, tune, seek, scan, function, play/pause, stop, mute, etc...
