Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Speaking of Blackstone Labs... 'You have added 900 miles to your oil use since last sample, and wear from your 98 Contour engine actually improved quite a lot. Since we didn't find any problems in the oil of the last sample, we have no idea as to the reason for the improvement. Perhaps the oil cooler is a factor. Silcon improved, so possibly the air your engine is breathing is cleaner. both air and oil filtration were functioning normally while this oil was in use. This was 5W/30 engine oil with no gas, moisture or anti-freeze in it. Nice 2.5L!' As Jay said, this is where it counts the most!  This was a sample with 3900 miles on it. Next sample I will send will have 4500 miles on it. So there, clean inside, slighty dirty outside.
Chris
NJ
98.5 SVT Silver Frost
Posts: 2,517 |
Who dat? I wonder how they'd like MY 2.5L. LOL
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Chris
NJ
Posts: 1,541 |
The only thing Blackstone bagged on for me was Si content. They say check my air filtration, but I think I know what the real culprit is: my disintegrating left precat. Not excessive, 31 ppm. If I could just get a yard to actually tell me that they warrant the d**n precats, even for just 30 days, I could buy one. I'm getting the following response, from more than one yard: "We sell the cat converter at extra cost, not included with the manifold."
Posts: 5,854 |
Did I read right? You want to reaplace the precat? Gut them my friend! Don't restrict that beasts breatthing any longer !!!
1999 Silver Frost SVT
#609 of 2760
Posts: 1,541 |
Originally posted by TheGreatOne: Did I read right? You want to reaplace the precat? Gut them my friend! Don't restrict that beasts breatthing any longer !!!
If I had to remove the firewall side manifold, then I would be all about gutted. I'd buy a set from Brad Noon. However, I am "lucky" enough to only have to replace the radiator side manifold, and you couldn't make me gut them on the motor. Having only one gutted manifold sounds like bad mojo to me, so I'm taking the path of least resistance (and cost) for now. Ford wants $500 for one manifold! Don't worry - headers (or gutted cats) are in the long term plan, but I just can't justify them right now. I'll be hanging on to the bad manifold for just that. Now if I could just find a yard that doesn't have "head in butt" disease ...
Posts: 3,143 |
How often do you send your oil in? It's 18.50 a pop
"Bros before Hoes" <-- More men need this mentality.
Posts: 1,541 |
I just did it for the first time, and now that summer is over I shouldn't be putting 5000 miles (my change interval) on every 2 months. $18.50 is a small price IMHO to have the ability to identify potential problems before they become serious. I see it as periodic "blood tests" on my engine. Don't want that cholesterol to get too high ...
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
I send it on both cars, every oil change. I consider it as preventative maintainence.
Chris
NJ
Posts: 5 |
the guy is a dirt bag of course. probably from corinth ny trailer trash. his other car must be a grand-am with the plastic falling off and no hub caps
svt from clifton pk. ny t-red stock 30mpg @80mph mint...
