Posts: 59 |
I installed my KKM today, but the screen on the MAF didn't fit between the adaptor and the MAF. Should I MAKE it fit? Or will it be ok without it? Thanks!
Mathew 98 blk E0 CSVT
Posts: 308 |
Keep it out, I did
99 SVT Green/Tan #44 TH-Fix, Aussie Pipe, PRO-M, SHO-Shop Y, Borla, and other Misc. 93 Tracer LTS Eibach, K&N, Misc (now my winter beater) email me: keith@thinkingcapdesign.com My Car: http://www.thinkingcapdesign.com/KeithsSVT/
Posts: 3,419 |
Or spend $5 and get the gasket from BAT that will allow you to use the screen. It's in there for a reason.
Posts: 316 |
I would like to buy a used MAF screen.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 59 |
How much performance will I lose if I do use it? I don't imagine it could make but the smallest difference?
Posts: 316 |
Sell it to me, I will dyno with it and without it, and document the results. I am 95% ready for the dyno. New alternator, new optima battery, intake almost done, waiting on inlet pipe, exhaust done, a/f ratio tuned.
Posts: 59 |
Sorry Hoosier I'm gonna get that gasket PA 3L mentioned and keep it. Sounds like you really want it though, sorry...
Posts: 2,112 |
I took off the rubber gasket and just squeezed it inbetween the MAF and MAF adapter. The screen isn't anything special; you can cut out a piece of window screen (preferably some water-reactive metal like aluminum or ss) and it'll work just fine. All it does is smooth out the turbulence that conical filters sometimes causes.
Posts: 654 |
Should all cars have this screen everyone is talking about?? I dont know if I had one before I installed my KKM setup. Is there a picture of the screen anywhere??? Thanks... -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 36 |
I have the KKM installed on mine for about 5 months now without the screen. Works good so far on mine.
*99 Contour Sport SE*
-KKM Intake- -Res Removed- -Matrix blue headlights- -Custom Dual exhaust- -Mystery Mod- -Removed turn single reflectors- -Fog Light fix- -Pioneer Head unit-
