Posts: 3,237 |
I changed mine last night and tipped out the contents afterwards, on a sheet of paper towel. I sh i t you not, mud came out, only after maybe 12,500 miles! Explains some sputtering I was experiencing, although I think my "top quality" OEM fuel pump is slowly on the way out! But in any case change the bloody thing, it only costs like $5 and take 10 minutes to do. After your done tip out the fuel as to strain it, on a paper towel, and you'll be AMAZED at the crap that makes it's way into you tank.
Posts: 7,329 |
I change mine every year.
Cheap & easy insurance.
Posts: 2,906 |
not to mention the wonderful taste of gas and the aromatic properties on the skin
mmmmmmmmmmmmmmmmmmmm
Spattmobili®
Posts: 3,237 |
Originally posted by Spatt and such: not to mention the wonderful taste of gas and the aromatic properties on the skin
mmmmmmmmmmmmmmmmmmmm I didn't say anything about drinking it!
Posts: 2,906 |
no choice.... and low and behold: NO AUSSIE SIG I'll see you monday, bring $20
Spattmobili®
Posts: 164 |
A couple of questions... How did you relieve the fuel pressure from the system? Do you have the "special" tool or some other method? Was the replacement filter a dealer only item?
- Jim
'96 Mystique GS, Ztech - ATX, with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
Posts: 316 |
Pull the fuel pump fuse, then crank the car three times.
Fuel Filter available at Autozone.
I did this along with other maintanance before I installed the SHM MAFterburner.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 42 |
Excellent reminder. It's such an easy to forget, out of sight, out of mind maintenance step. Super easy to replace, too. And made a big difference once I did. If I can do it ....
Luigi 1997 SE, black, MTX, BAT suspension kit, resonatorless, Dynomax Superturbo, Corbeau GTS-II driver's seat, seven spoke SE wheels, K&N, tranny cocktail, Mobile 1
Used 96 Duratech with 35K installed at 92.5K due to engine fire. Replace your water pump today!
Posts: 249 |
Might sound like a stupid question but where is the fuel filter located on the Contour?
~~~~~~Mike~~~~~~ Silver 2000 Contour SVT # 1200 of 2150
Posts: 918 |
Passenger side under the back door. Simple to replace, I did it without lifting the car.
************************* 2000 SE Sport V6 Deep Navy CC Metallic My 2G Sport *************************
