#41994 05/24/02 06:35 PM
I changed mine last night and tipped out the contents afterwards, on a sheet of paper towel.
I sh i t you not, mud came out, only after maybe 12,500 miles! eek
Explains some sputtering I was experiencing, although I think my "top quality" OEM fuel pump is slowly on the way out!
But in any case change the bloody thing, it only costs like $5 and take 10 minutes to do. After your done tip out the fuel as to strain it, on a paper towel, and you'll be AMAZED at the crap that makes it's way into you tank.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#41995 05/24/02 07:08 PM
I change mine every year.
Cheap & easy insurance.
2000 SVT #674 - Check it out!
#41996 05/24/02 07:40 PM
not to mention the wonderful taste of gas and the aromatic properties on the skin
mmmmmmmmmmmmmmmmmmmm
Spattmobili®
#41997 05/24/02 07:41 PM
I didn't say anything about drinking it!
Regards,
Anastazi
#41998 05/24/02 08:10 PM
no choice....
and low and behold:
NO AUSSIE SIG eek laugh
I'll see you monday, bring $20
Spattmobili®
#41999 05/24/02 08:34 PM
A couple of questions...
How did you relieve the fuel pressure from the system? Do you have the "special" tool or some other method?
Was the replacement filter a dealer only item?
confused confused
- Jim
'96 Mystique GS, Ztech - ATX,
with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
#42000 05/24/02 08:38 PM
H
H
Pull the fuel pump fuse, then crank the car three times.
Fuel Filter available at Autozone.
I did this along with other maintanance before I installed the SHM MAFterburner.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
#42001 05/24/02 11:14 PM
Excellent reminder. It's such an easy to forget, out of sight, out of mind maintenance step. Super easy to replace, too. And made a big difference once I did. If I can do it ....
Luigi
1997 SE, black, MTX, BAT suspension kit, resonatorless, Dynomax Superturbo, Corbeau GTS-II driver's seat, seven spoke SE wheels, K&N, tranny cocktail, Mobile 1
Used 96 Duratech with 35K installed at 92.5K due to engine fire. Replace your water pump today!
#42002 05/25/02 02:03 AM
Might sound like a stupid question but where is the fuel filter located on the Contour?
~~~~~~Mike~~~~~~
Silver 2000 Contour SVT
# 1200 of 2150
#42003 05/25/02 02:56 AM
2
2
Passenger side under the back door. Simple to replace, I did it without lifting the car. wink
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
