#419526 08/23/02 11:48 PM
9
I'm considering purchasing a DMD for the car, and as I've heard it's a good investment. But my question is, if I have an engine failure with the DMD installed, would it be possible, or likely that Ford would come back and say, "sorry, your new harmonic balancer voided the engine warranty"? I've got the Ford ESP on it, so if anyone could fill me in, I'd appreciate it.
Thanks.
1999 SVT Contour - SOLD!!!!!!! 2003 Mach 1 =)
#419527 08/24/02 02:33 AM
I'd say with the way Ford can be, yes it will void the warranty. Even though its a Ford (of Europe) OEM part. However, the chances of a Ford mechanic noticing you put on a DMD might be rather small. Maybe someone else more knowledgeable can chime in with some better answers.
'99 SVT Contour 1298 of 2760
#419528 08/24/02 03:36 AM
I bet a local yokel Ford dealer that stumbled across the DMD could try to "void your warranty". Once you went up the food chain and made people look into the DMD and its application, I seriously doubt a good case could really be made for the DMD causing failures.
#419529 08/24/02 03:39 AM
It has the same part number and Ford Stamping. I serously doubt any Ford Technician will even notice.
Lee Cox No Contours to speak of...
#419530 08/26/02 07:08 AM
I had mine installed by the dealer and they told me since is a ford part for this specific engine (2.5 Duratec) and poses the same part # is not a problem.
the rats are on the cheetos again Jet mechanic 98 silver frost SVT DMD Modified Intake First SVT to see the world Keenwood 10CD CHANGER, 12" JBL,4 CV
#419531 08/26/02 03:39 PM
I'm wondering if anyone has had an engine failure with the DMD installed. I would like to start taking right hand sweepers the way they were meant to be taken - FAST. Yes - I use a full 6 qts, of Mobil 1 and I have a DMD (thanks to my buds at NE-CEG).
Doug 2006 Mercury Milan V6 Premier Dark Blue Pearl Former owner of a 2000 SVT Contour
#419532 08/26/02 07:19 PM
what you might do is take it to your dealership and have them install it if your worried about your esp.... if you had an engine failture and a cert. ford service dude installed a ford part i think it'd be hell for them to attempt to call you out on it.
-Matt "Pain heals, chicks dig scars, and glory lasts forever!" will do/pay just about anything for the following parts: CF sunroof glass replacement OEM CF trunk Non OEM style cf or fiberglass hood not the cf1 design
