Posts: 10,015 |
I don't think so, the mounting depth of the caliper to the rotor would be the same, so the bolts should be carry over. Nonetheless, for your own peace of mind you might want to install new ones anyway.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 10 |
Hey Tony let me know how this goes for you... I'm interested in upgrading to SVT brakes this spring as well. If it is just the brackets hopefully it will be pretty cheap (besides larger rotors..)
Thanks Kevin Marold
-= '98 SE Sport MTX =-
KKM Intake
17" Turner 10spoke
BAT Euro Kit
Posts: 319 |
Can you give me a price for the front rotors and pads. Also if you have cadium plating avaliable quote me that price. I have already upgraded the rear drums to disks!
EDIT:
I was just quoted $270 cdn for the pair of caliper brakets for a 2000 CSVT!!!!
1998 Contour SE
Panasonic CQ-DFX683
Sound by Crystal Mobile & Illusion Audio
Powered by Alpine MRP-F240, Alpine MRP-M350
My Ride
Posts: 10,015 |
$130(+ shipping) for a set of front rotors and pads.
Cadmium plating on OEM style rotors is not available.
AUSSIE ENDLINKS $70
Posts: 472 |
what is a svt brake upgrade? how much would it cost i have front disc and rear drums ,
what kind of mod is there for rear drum brake-- convert to disc?
can i just do the front upgrade?? doesn t make sense
96 gl sport, atx, rip at 95k
FDNY 343 remember 9/11
Webmaster
Webmaster
Posts: 1,359 |
Originally posted by ddmd3216: what is a svt brake upgrade? how much would it cost i have front disc and rear drums ,
I guess no one reads the site other than the forums.... Like this...-Lance
Lance Kinley
CEG Webmaster
95 SE, "Cassandra"
10 years!
Posts: 10,015 |
Doing just the fronts would be fine. This is because the rear biasing is soooooo weak on our cars that going to the trouble of converting to discs is probably not worth it unless you are planning SERIOUES track work. Just upgrading the fronts to the SVT size rotors will make more than enough difference for most people.
And like I said before, I can supply you with the pads and rotors to do this but you WILL need to get SVT caliper brackets to suit a 2000 SVT from the dealer, to complete the transformation.
AUSSIE ENDLINKS $70
Posts: 10,015 |
AUSSIE ENDLINKS $70
