Master P
Master P
Posts: 5,455 |
oooopps... wrong chris, sorry. Chris A. in NJ has offered to donate parts, and I was dummy and neglected to look at the last name. My mistake.
Posts: 7,329 |
Posts: 3,248 |
Thanks Lance, super job your doing.
Dan
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 4,983 |
Keep up the good work Lance!  ------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX "Regla de los Contours!" My Car's Page!
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 38 |
Thanks Lance, The check is in the mai.....Paypal, if more is needed, ask, I am not rich but am willing to help. Tony
------------------ AntMowery@worldnet.att.net 98 SE V6 MTX SVT KKM intake, Pro Flow 75mm, No Resonate, VooDoo Knob, Fog Fix Headlight fix, 16 in Cougar wheels, SMA strut towers bars, SVT exhaust SMA straight intake, B+M edge, Bosch +4 86 MR2
Posts: 306 |
98 Contour GL V6
Current Mods: Mud Flaps
Posts: 3,043 |
Uhh... thanks.  ------------------ Flamenco Black Pearl 1999 Honda Civic SiIntegra Type R cams, ITR valve train, ITR ECU JUN cam sprockets, AEM Cold Air Intake, Custom cat-back Eibach Sportlines w/ Tokico HP's, ITR rear sway NO RICE!infuryum@onebox.com AIM:infuryum
Black '99 Civic Si cams and motorwork I am the anti-rice. -EPBurn integral@adres.nl
Posts: 2,657 |
Doing a great job Lance, Thank You!
Anonymous
Unregistered
Anonymous
Unregistered
Yes Lance ... Thanks a lot !! I can't afford to give a million , but I'll certainly pitch in something for this great site !~~~~~~~Allen
Posts: 506 |
LANCE IS THE MAN! Thanks for all that you do, Lance.
------------------ ---------------------- Ben Castle Rock, CO 1998 T-Red SVT #4406/6535 fast80svt@aol.com
