That front bumper is too flimsy for my tastes, so I used some aluminum and fabricated some brackets that mount to the front bumper bolts. I just need to tweak it a bit to get the right adjustment...like you guys, my bumper doesnt allow me to adjust the beams as high as I want them to be.
As for wiring, I decided to use the supplied PIAA harness and switch. HOWEVER, I wired the switch to the factory relay so that the factory switch controls when the fogs go on and off so long as the PIAA switch is "on." I just tucked the PIAA switch under the dash and you can't tell that its even there, and it works like the factory fogs to boot.
The installation took WAY longer than I had hoped, but once I get the adjustment down, I'll be VERY pleased with the PIAA. Now I gotta get new lamps for the headlights...the factory ones look too yellow.
