Posts: 1,361 |
Can you machine cross drilled and or vented rotors when it's time to change your pads? I have thought about buying some but I don't want to replace the rotors every time I have to change pads!
'98 SVT Contour, in at least 639 pieces
4 Speed MTX...synchro and shift fork replacement in progress
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
I've heard it's possible but they way I've seen them machined no! Either way you would be hard pressed to find a shop that would do it for you! Basically they are throw aways!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 1,361 |
Damn, that's really a waste of money of you don't race then. Oh well. After breaking my SVT I'll probably look more into racing my Monte. Thanks for the quick answer!
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
That is why I suggested the OEM Autospecialties! They are a quality rotor, unlike Bat Econo's, to replace OEM parts. I have slotted and drilled on the front and if they warp, I'm done. I've been lucky so far! A harder compound pad like KVR's on Mintex 1144 will take longer to wear out with street use but also don't brake so well when cold! I run KVR's all around!
-Andy
Andy W.
Posts: 2,023 |
It's a waste of money even if you do race according to people who make rotors.
Cross-drilled, etc. are for cosmetics, aesthetics, and looks.
-Giovanni
One turbocharger. Two intercoolers. All love.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
That is so you don't get a false impression of better braking simply from rotors. Some racing teams do use slotted rotors but not most! They also you light weight two piece rotors!
-Andy
Andy W.
Posts: 2,023 |
I was referring to the strength reasons but good points.
-Giovanni
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
What do you mean by strength reasons?
-Andy
Andy W.
Posts: 2,023 |
You know this but I'll say it anyway.  Rotors constantly heat up and cool down, and being metal, that means constant contracting/expanding. A solid piece will handle this better than one with holes drilled all over creating lots of stress points.
-Giovanni
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Ausgedient: You know this but I'll say it anyway. Rotors constantly heat up and cool down, and being metal, that means constant contracting/expanding. A solid piece will handle this better than one with holes drilled all over creating lots of stress points.
HELL NO! I know this first hand. I have had 2 sets of stock replacements and BOTH warped due to normal street driving. I put a set of crossdrilled and no warping in street driving, road racing, or drag racing. My stock brakes would GLAZE if I tried to stop quick on the highway. I don't have this problem with the CD.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
