Page 3 of 4 1 2 3 4
#418785 08/29/02 11:47 PM
Originally posted by PA 3L SVT:
Originally posted by TommyBoy:
How do you tell if your car has a returnless fuel system???
My car was buit in 9/97, so what gives am I able to use VCM-1000,Turo, or Vortech.....
Look under the TB and UIM - if you see a vacuum actuated fuel pressure regulator on the fuel rail, then you are return fuel. If not, you are returnless. With your build date, I'm pretty sure you are return fuel.
So does that mean I cant use the venom Kit??????
1998.5 CSVT #3617 K&N Custom Intake Custom 2 3/4 Magnaflow cat back Ram HD Power Grip Clutch Energy Suspension Inserts Bosch Platnium + Bf-Goodrich G-force radials "KDWS" Alpine deck CDA-7863 Boston mids More to come: Stock Sucks!!!!
#418786 08/30/02 03:01 AM
Sorry for my ignorance but does this fuel regulator look similar to the egr attched to a hose?? I also need to know if my svt is returnless or not. I have a 99' so its a toss-up
Brian 2004 Nissan 350z Touring brian8064@hotmail.com
#418787 09/01/02 11:49 PM
A lil help, Anyone
#418788 09/02/02 10:36 PM
my guess is that you can run the kit on your svt...
#418789 09/08/02 02:15 PM
W
W
It would be smarter and cheaper just to plumb a second fuel line from the tank with its own pump. Let the stock system work as intended, you would have to change out the pcm as well when you went to a return style system, what do you think controls the fuel pump in that type of system?
Running a dedicated second line would be better because you would easily overcome the limitations of the stock fuel line in flow volume. Plus you have other added flexibility.
warmonger
#418790 09/08/02 02:22 PM
W
W
I believe the 99 cars are mostly return-style systems and the 2000 cars are all returnless. If venom says it will work for a 99 and up, then it would have to work with both systems. Just to be sure you can call and ask them.
The return style systems have the pressure regulator on the fuel rail. If you look at an angle to the engine just below the throttle body you can see it. Yes it looks like a small version of the egr valve actuator. The other indicator should be a return fuel line. It will be coming out from the manifold by the fuel feed line and should be smaller in daimeter.
warmonger
#418791 09/08/02 02:31 PM
W
W
So what are you going to do with your supercharger since you aborted it? Interested in selling it?
warmonger
#418792 09/08/02 03:10 PM
warmonger
Well I am not because I didn't buy it. I was only going to buy it from the guy if we could get it installed.
#418793 09/08/02 03:12 PM
I called venom and they said the kit will work on any year SVT...
#418794 09/08/02 03:13 PM
warmonger
Who was selling it? I'm close to you, same state, anyway! I might get it... I'm assuming it was a Vortech and not the hurricane blower eram thingy...
Now owner of 0 SVT's. my web page
Page 3 of 4 1 2 3 4
