Page 2 of 4 1 2 3 4
Use the same belt currently fitted to your car,the belt length does not change with a DMD... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Terry-
I think the belt length did change with the TSB, and part of that was due to a different idler pulley. Any way you can confirm this for me?
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
E
E
Terry is saying that the DMD is the exact same diameter as your current existing crankshaft dampener pulley...so, no belt change will be required. Unless you change something else during the DMD installation, you will use the same size belt!
Ed
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
OK, but what I am saying is that they changed both the crank and idler pulleys, and the combination required an altered length belt. If I change just the crank pulley back to original size (ie. install the DMD), there is a possibility that I will need a different length belt from the standard or altered length that is currently installed. This could leave me needing a belt that does not exist.... ...and therein is my question.
DMD Installed
SVT Brakes
Just measure the dia of your existing damper............
V6 MTX
OK, any idea what the diameter of the standard damper pulley is?
Also, I heard that we can buy these from you?
DMD Installed
SVT Brakes
The OD of my stock pulley (sitting in the closet) is 6.5".
Originally posted by G Pappas:
[QUOTE][qb]..... Also, you don't want to [b]quickly turn the pulley in a clockwise direction either, since it is possible (although doubtful) to start the engine that way.....[/b]
First step! Disconnect the battery! The car won't start without it!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
OK, thanks PA, I'll have to measure mine during my next oil change.
DMD Installed
SVT Brakes
First step! Disconnect the battery! The car won't start without it![/b]
I was just quoting what I read out of the Haynes manual. Never tried it myself and don't plan to anytime in the near future either wink .
Are you saying that (a) the car won't crank over or that (b) once the car is started (i.e., cranked over) that it will stall?
I am not a mechanic, but I believe that there are plenty of engines that run without batteries (lawnmowers, weed wackers, mini-bikes, remote-control airplanes, etc.). The way that you get them to start is by "cranking" the engine. I believe that this is done by turning the crankshaft at a sufficient speed until the engine fires and then can continue firing on its own. For example, the way to start a lawnmower is to pull the ripcord (or whatever it is called) a gazillion times until the engine turns over and starts. I believe that this method was also the way that they used to start cars back in the "good old days" (before my time smile ).
I am pretty sure that the Contour engine can be cranked in the same way. And if a fully-charged battery is connected, I am pretty sure that the car would turn over and continue to run.
So I guess the question is "will the Contour continue to run if the engine is cranked sufficiently without the battery connected?" In other words, does the circuit from the battery need to be completed in order for the car to continue running. Maybe one of the electrical gurus on this board can answer that question.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Page 2 of 4 1 2 3 4
