I understand the tooling I will need is basically a harmonic balancer puller and a tool to move the tensioner pulley to get the belt on and off.
You will also need the following tools:
- A 10mm wrench or socket/ratchet for removing the splash shield from the right front tire.
- A breaker bar to loosen the crankshaft pulley bolt tension (it's on there pretty tight).
- A tool to hold the crankshaft pulley as you try to loosen the bolt tension and also when you install and tighten the
NEW bolt. I used the setup that is displayed in
edorfox's excellent pictorial.
WARNING: You don't want to turn the pulley in the counter-clockwise direction. According to the Haynes manual, you can bind up the timing chain. Also, you don't want to quickly turn the pulley in a clockwise direction either, since it is possible (although doubtful) to start the engine that way.- An installer tool. I used an M12 (width) x1.5 (thread) x90mm (length) bolt that I bought at Yates/Carquest ($2.60). I used it in conjunction with the old crankshaft pulley washer and a set of 1/2"-drive sockets. Here is a
picture of what I am talking about.
- A torque wrench that will be able to apply 35-90 ft-lb of torque.
- Extensions for the breaker bar and torque wrench. I believe that I used a 10".
- A jack and jackstand to support the car.
- High-temperature RTV sealant for the crankshaft pulley keyway.
I heard a rumor that the mounting bolt for the pulley needs to be changed when a new damper is installed. Is this true?
Yes, the crankshaft pulley bolt is a torque-to-yield (TTY) bolt, which means that it is
one-time use only.
Is this bolt a special bolt that is specific to the duratech (if so does anyone happen to have the part number for it) or is it a standard SAE or Metric bolt (What is the size, length and grade I need)?
The part # for the crankshaft pulley bolt is F5RZ-6A340-B ($3.10 @ dealer) and the size is M12x1.5.
The torqueing procedure for the
NEW crankshaft pulley bolt is as follows:
- Tighten bolt to 120 N-m (89 ft-lb)
- Loosen bolt a minimum of one full turn
- Tighten bolt to 47-53 N-m (35-39 ft-lb)
- Rotate bolt an additional 85-95 degrees
The part # for the crankshaft pulley washer is F5RZ-6378-A ($4.29 @ dealer)(if you decide to get a new one).
Some additional tips:
- If you have MTX (manual transmission), put it in the highest gear and apply the emergency brake.
Caution: Don't use a rubber mallet and wood block to pound the DMD on. This can damage your crankshaft internally.
- After loosening the old crankshaft pulley bolt, you don't need to take it out (just yet). You can use it, as louisw says, as a base for the puller to "push" against. This will protect the threads in your crankshaft pulley.
- FYI: It took me about 3.5-4 hours total, but an hour was spent searching for the installer bolt that I didn't realize I needed. I had to go to four different auto supply stores before I found it. I also took my time on this, since I am not a mechanic and it was the first time that I had done any kind of work on the engine.
- I also ended up breaking a 3/8"-extension when trying to loosen the old crankshaft pulley bolt. It was probably because it was a cheap one that I bought about 15 years ago.
Another good website for helping to install the DMD (even though it is about installing a UDP) is
Lance Kinley's How to install an Underdrive Pulley (UDP).
Hope this helps.
