If your vehicle is the 2.0L, then it is no problem (according to the Ford TSP).
If your vehicle is the 2.5L, then you will need to remove some stuff that is in the way. I believe that if you remove some of the hoses above it (specifically the IAC valve air tube and the evaporative emissions hose), then you can get to it, but you will still have a time getting your hand down there with a tool.
You will need to remove two nuts, two hoses, and the electrical connector.
I did it last weekend and it went OK. You will need either a deep socket or an extension for mobility. Make sure that you have a magnetic pickup tool or extended claw for the nuts that you are bound to drop down into the engine.
I ended up dropping one of the nuts after loosening it.
Also, make sure that you label the two hoses that come off of it (it won't work if you reverse them).
