Originally posted by smoothy: Smoothy will not rev past 4k anymore...
Are you trying to rev the car in Park or Neutral? If so, I believe that there is a governer/limiter on the car that prevents it from revving beyond a certain RPM range.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
