Posts: 98 |
I got a bunch of supplies from working at 3M and I went at my manifold and it turned out great. I decided to buy all the stuff to do it so I could polish up a few. If anyone is interested check it out here: Click Me Send me an email or PM me if you are interested: svt0@hotmail.com
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed: svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
Posts: 1,681 |
wow, that looks great. do you have a larger image of the uim?
Posts: 98 |
The pictures in the post should be pretty big. Scroll down in the post and you will see them attatched at the bottom of my first post. Otherwise I can run out and snap a shot and get it up in a few min if you want something bigger. I don't thing NECO can handle large images though.
Posts: 1,041 |
Check out my Mods Section on my Web Site. Jet Hot Ceramic Coated. But Damm that looks very nice! Good Job!
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 3,562 |
Can you post pictures or part numbers for the tools you used? I've been going to polish and clear powder coat mine for quite a while now. I've just pushed it off because sanding drums, then cotton wheels with compounds take a long time to do. Just wondering if anything you used is easier.
Good luck with that SVT UIM. I know Rick has had quite a time stripping his with the media blaster...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 7,329 |
Heat soak is bad enough WITH the coating!!! I can understand cleaning it and coating is with something better maybe, but give me performance over a shiny UIM any day...
Posts: 176 |
I can understand cleaning it and coating is with something better maybe, but give me performance over a shiny UIM any day What are we talking 10 degrees, 20 degrees, shoot for that I'll take the looks on peoples faces when I open the hood
2000 Roush Cougar MTX MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Posts: 1,041 |
Originally posted by DemonSVT: Heat soak is bad enough WITH the coating!!!
I can understand cleaning it and coating is with something better maybe, but give me performance over a shiny UIM any day... Who are we refering to? Ceramic Coated or Polished?
Posts: 98 |
He is referring to polished. He is sending his to me for some polishing. Hey Brad I doubt it is much easier my way. It takes a long time to sand it down (12hrs) and then lots of good industrial strength aluminum polish. I wouldn't ask for $250 if it was a piece of cake.
Posts: 7,329 |
Originally posted by Speed Demons: Who are we refering to? Ceramic Coated or Polished? Bare metal. Don't worry I think ceramic coating is good! BTW folks - even 20 degrees is a big difference! High compression, high rpms, lots of timing - yes 20 degrees is a lot...
