#41638 05/13/02 02:03 PM
Merlin Offline OP
In the back of the new Muscle Mustang&Fast Ford it has a couple pages on Sho Shop modified SVT Oil Pan. Did not know if any of you have looked or not.
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
#41639 05/13/02 04:29 PM
I have it. They didn't do their math right and the dipstick doesn't go back in the "notch" in the stock piece, so your oil level reading is no good. You'll have to install it, jab the dipstick into the pan a few times to get marks to show you where to cut, remove it and cut the notch bigger, and then reinstall. The only reason I realized this was that I had to drop my oil pan to replace the gasket. Poor design on that point IMO, but otherwise its a nice little piece. Wish I had brought my camera when I did that, but I wasn't expecting to discover that problem, and I'm not dropping the oil pan again.
#41640 05/13/02 06:48 PM
How big of a job is it to swap oil pans?
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#41641 05/13/02 06:53 PM
The kit I have is an add on to the existing "baffle" in the oil pan. Not sure if the item in question is a new oil pan or the same kit as I have. Pulling the oil pan will take a few hours, and you have to do it twice to make the kit I have work. Maybe people can do it quicker than me (I work slow), but the toughest part is doing everything while laying on your back under the car.
I posted a how to on changing the oil pan gasket (probably in Problems), so a search will certainly bring out the instructions needed. Or you can look in the mailing list archives, where I posted the same thing.
