Posts: 11 |
Okay I've got a problem now. I when I say my car pull up it looked unbalanced, and at first I thought my parents had brought something heavy home, but after the car was emptied I measured the distance from the top of the wheel well to the ground on both sides and there was almost an inch difference the right side was 27 inches and the left was just over 26. What could be causing this? Is it like that normally to offset the weight of the driver? Or is there something wrong with my car. I'd guess this is the first thing to do would be an alaignment but I thought it would be best to check here first. I also found that the left spring was compressed more than the right one. Oh, yeah and it was on level ground so TIA Peter
98 MTX SE sport
and a turbo MR2
Posts: 667 |
I would push up and down on both sides (front and back) and then measure it a few times to make sure that it isn't a fluke.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 1,631 |
Hey.. I had a Dodge Daytona that was like that !! But the thing is... the car was in an accident and they had to redo part of the frame...  I don't think that is your situation... (did you buy the car used ??  )
Anything is POSSIBLE... sowing the seeds of love"
Posts: 5 |
This may be totally off, but...
Have you checked for broken springs? I recall there were threads on that topic some time ago, before the new software.
Joerg
Posts: 2,676 |
Mine is to, but I've lowered it with Eibach's + Koni's, and I'm starting to think the Eibach's have been shot to hell, so I'm putting the stocks back on this week or next, and sending the Eibach's back. I'm sure it's the springs dude, it has to be, at least that's what I'm telling myself. I'be got a .5in difference. First thing you should do before you waste money and time swapping coil springs is get an alignment, slight negative camber on the right wheel (or left) can cause the car to be slightly lower on that side(I did the same check, I have -2.7 on the left, and -2.8 degrees on the right, the side that was lower). BTW, this is NOT normal and don't let any shop convince you of that, because the people that isntalled my springs were adamant that this is the case on all cars, .5inch-1 inch differences.
Suneil
Posts: 600 |
There must be something wrong?? do you have lowered springs on it??
John
Was 96 Contour Zetec RIP
Now 2001 Chrysler 300M....
I Will Have Another Soon...
I AM NO TRADER......
Posts: 11 |
Well, the car has never been in an accident (we're the original owners), and the the suspension is all stock, minus the aussie bar. I guess I'll get it checked at a trustworth mechanic, as I haven't the experience to inspect the suspension properly. Thanks for all the help. Peter
98 MTX SE sport
and a turbo MR2
Posts: 1,603 |
Did you check the TIRE PRESSURE ?
It is normal for some variance in height. I would accept an inch.
3 - 4 inches is a problem.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 51 |
Yeah tire pressue was the first thing I checked, and even if it was off it wouldn't explain why one spring was compressed more than the other.
98 MTX V6 SE Sport
05 RSX-S
and a Turbo MR2
Posts: 1,603 |
One Inch is not a lot of variance. If you want to, look at it this way... First the floor is NOT perfectly flat. Second, if you compare right to left, you could say that one side is 1/2 inch higher than it is supposed to be, while the opposite side is 1/2 inch lower than it is supposed to be. Don't dwell on it. If the steering is straight, and the car rides fine, leave it alone...
Pete...
DOB 10/31/2003
DOP 1/2/2004
